[mapserver-users] Questions about PHP Mapscript and Queries
Hankley, Chip
Chip.Hankley at GASAI.Com
Tue Jul 30 11:11:51 EDT 2002
Frank...
I guess I was trying to logically "weed out" where the problem might lie.
Your check in AV pretty much rules out a problem with the conversion from
pixel to geo. I'd go back to your original function, and look at something
else.
The next place I'd look is your mapfile, and the syntax around your
queryByPoint.
Mine looks something like this:
@$map->queryByPoint($click_pt, MS_MULTIPLE, -1);
$Layer = $map->GetLayerByName($lyr);
$count_results = $Layer->getNumResults();
//$lyr would be the NAME specified in the mapfile.
The layer definition for a layer I was querying would look like this:
Layer
NAME FIBEROPTIC <-- THIS is the name you specify above
Type Line
STATUS ON
MAXSCALE 15000
TOLERANCE 10
TOLERANCEUNITS feet
DATA "fiber_new"
METADATA <-- THE 'METADATA' section is crucial if you want to retrieve
some data
"DESCRIPTION" "FIBER_INFO"
"RESULT_FIELDS" "ID MH1 MH2 HYPERLINK"
END
CLASSITEM 'ID'
CLASS
NAME 'selected'
TEMPLATE "ttt_query.html" <-- THIS line is critical
EXPRESSION ' '
SYMBOL 'solid_line'
SIZE 2
COLOR 255 0 0
END
CLASS
NAME 'existing'
EXPRESSION /./
SYMBOL 'solid_line'
SIZE 2
COLOR 0 255 0
END
END
