[mapserver-users] editing shp files
Tyler Mitchell TMitchell at lignum.com
Tue Jul 30 14:07:16 EDT 2002
FYI
I can't seem to find docs about using shptree under the documents section
of the mapserver web site (did I miss them).  But I did find it on the
mapserver wiki page: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?ShpTree
                      "Lowell.Filak"
                      <lfilak at medinaco.org>               To:       David Turover <dturover at student.santarosa.edu>
                      Sent by:                            cc:       <mapserver-users at lists.gis.umn.edu>
                      owner-mapserver-users at lists.        Fax to:
                      gis.umn.edu                         Subject:  Re: [mapserver-users] editing shp files
                      07/30/2002 09:31 AM
In the directory where mapserver was compiled you should see a shptree
executable that will create the indexes needed/used by mapserver.
Lowell
On Tue, 30 Jul 2002, David Turover wrote:
> On Tue, 30 Jul 2002, Lowell.Filak wrote:
> > I can quickly see two possibilities:
> > 1) Create an index on the shapefile and things may speed up to an
> > acceptable pace.
> I hadn't heard of indexing shape files before, so I did a little googling
> and in the process found a doc which explains the makeup of shapefiles
> better than I did in a prior post:
> http://www.uiowa.edu/~osa/gisatosa/howto/filetypes.html
> I've also seen .prj files (projection) and .shp.xml (XML formatted
> metadata about your shapefile), which aren't mentioned on this page.
> I don't think mapserver has support for sbn/sbx/ain/aih files, although I
> would love to be corrected.
