[mapserver-users] GD/Freetype Problem (was: No Image Output)
Alexander Pucher pucher at atlas.gis.univie.ac.at
Wed Jul 31 03:32:51 EDT 2002
Bryan Tolka wrote:
> Have you recompilied PHP with the switch without-ttf? On most RPM
> installs it seems to be complied in, on RedHat it was.
I thought that was just for pre 3.5 version of mapserver!
> You also need to compile freetype 1 with gd.
I really tried out every imaginable combination of GD and Freetype
without success.
> Mine all works this way.
Do you use SuSE and if so, did you remove some packages with YAST2
before starting your builds?
alex
> Alexander Pucher wrote:
>> Daniel,
>> sorry, but no, my build does _not_ work, unless I comment the
>> 'Label'  sections in the Gmap map file or I uncheck the 'Pop.Places'
>> layer, which uses TTF!!!
>> Some more general questions, before I start it all over again on a
>> clean system. I work on my private notebook, so setting up the whole
>> thing again is no big deal!
>> Does 'SUPPORTS=TTF' in the 'mapserv -v' output:
>> MapServer version 3.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE
>> of my CGI mean that my mapserver executable supports Freetype 1? As I
>> understood, TTF refers to  Freetype1 whereas FT ~ Freetype2 in all
>> Makefiles etc. of the GD, PHP and Mapserver builds and configures. Is
>> that correct? Does otherwise Freetype2 support show up with something
>> like 'SUPPORT=FT' or 'SUPPORT=FREETYPE' ?
>> Can anyone on the list report on a successful build of mapserver
>> 3.6.1 on SuSE 8.0 with any GD/Freetype support?
>> What about using GD 2 or the newest mapserver nighly built. Should
>> this change things?
>> Regards,
>> alex
>>>> checking for gdImageStringFT in -lgd... yes
>>>> checking for gdImageString16 in -lgd... yes
>>>> checking for gdImageGifPtr in -lgd... yes
>>>>        using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
>>>> -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR) from system libs.
>>>> checking whether we should include PDF support...
>>>> According to the MapServer Unix HOWTO, I should not get DUSE_GD_FT but
>>>> DUSE_GD_TTF, when building with Freetype1 !!!
>>> Hummm... you're correct that we would expect to see -DUSE_GD_TTF for
>>> freetype 1.3, that's odd... I checked on one of our servers and I get
>>> the same -DUSE_GD_FT as you with freetype1.3 and my truetype fonts work
>>> well, so I would suggest that you continue with your build... it's
>>> probably going to work.
