[mapserver-users] Display GeoTIFF raster data
Stefan Stern mail2stern at gmx.net
Wed Jul 31 10:11:56 EDT 2002
Hi all,
First thanks for all your sugestions!
I created 3 subset image from my dataset [unsing ENVI]:
1)  .BMP with an additional world file [.wld]
2) .TIF 8bit grey with an additional world file [.wld]
Unfortunately all files didn't work out (appeared in mapserver).
So I guess the error is in my mapfile, which looks pretty equal to
the tutorial one  [in my eyes ;-)].
##################### myfile.map #####################
NAME URGENT
EXTENT 266341.5 191854.5  267340.5 192853.5
#grid is ordonance survey GB
SIZE 300 300
SHAPEPATH "/home/.../data"
LAYER # Raster
  NAME "casi"
  DATA "subset_1000_1000_white.tif"
  TYPE RASTER
  STATUS ON
END#layer end
END # end of map file
I inserted each file (.tif, .png, .bmp) and none was displayed.
What do I miss out?
Thanks and Regards,
Stefan
Hankley, Chip wrote:
>Stefan...
>In addition to Perry's comments, you can always use some of the libgeotiff
>tools to help you manipulate your geotiff:
>http://www.remotesensing.org/geotiff/geotiff.html
>You can use the 'listgeo' program to generate an ESRI style world file, as
>well as to dump the contents of the geotiff into the standard geotiff
>metadata format. You can then, as Perry suggested, use your favorite Image
>manipulator to convert from RGB to indexed color, then go back and use the
>'geotifcp' program to convert the resulting tiff into a geotif.
>The results would be the same, you just wouldn't have to worry about
>maintaining a separate file. Also, if your original RGB geotiff has metadata
>information in addition to that covered by the standard ESRI style world
>file, it would be incorporated into your final Index-color geotiff as well.
>Cheers!
>Chip
>-----Original Message-----
>From: Pericles S. Nacionales [mailto:pnaciona at gis.umn.edu]
>Sent: Monday, July 29, 2002 2:31 PM
>To: 'Stefan Stern'
>Cc: mapserver-users at lists.gis.umn.edu
>Subject: RE: [mapserver-users] Display GeoTIFF raster data
>Are you using an RGB image?  If you are, you'll need to convert it into
>a bitmap (indexed color) image.  MapServer doesn't yet support RGB
>images.  Hopefully, your software can export GeoTIFFs.  If not, you'll
>have to create a world file (with extension .wld).  See Tom Kralidis'
>info about world files: http://www.kralidis.ca/gis/worldfile.htm
>Remember to use the extension ".wld" and not ".tfw".
>Most image manipulation software (i.e. Gimp or Photoshop) can convert
>RGB GeoTIFFs to bitmap but can't keep the GeoTIFF header.  If you use
>one of these software, you'll need to create a world file to add
>georeferencing to your image.  If you have an image processing software
>(i.e.: Imagine, Geomatica) you can export your bitmap image in GeoTIFF
>format and you won't need a world file.
>Of course you should also check your projections and extents...  If
>you're trying to overlay your image with the tutorial data, it won't
>happen.  If you're trying to overlay a Transverse Mercator (or UTM)
>projected image with unprojected (with lat/lon coordinates) vector data,
>it won't happen...  unless you already know how to reproject your data
>on the fly (that's section 4 on the tutorial).
>I hope this helps.
>-Perry
>From: owner-mapserver-users at lists.gis.umn.edu
>[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Stefan
>Stern
>Sent: Monday, July 29, 2002 7:40 AM
>To: MAPSERVER
>Subject: [mapserver-users] Display GeoTIFF raster data
>Hi NG,
>after spending some days on trying to display a GeoTiff image in
>mapserver I ask for your advice.
>Compared to the example used in the tutorial (
>http://terrasip.gis.umn.edu/projects/tutorial35/s2/s2ex3.html ) image
>dataset is more complex.
>It includes the following values for each pixel:
>Scrn: R:146 G:103 B:50
>Projection: GEOTIFF (Transverse Mercator)
>Map: 267457.50E,197788.50N Meters
>LL : 3.548576N, 1.228218W
>Data: R:136 G:102 B:68
>How do I display this image in mapserver?
>Do I need to rewrite header information of the source image or is it
>just a question of "How to display it in mapserver"?
>Is there some additional documentation / reference available?
>Thanks for suggestions.
>Regards,
>Stefan
