[mapserver-users] OGR versus PostgreSQL and XML-Mapfiles?
Stefan F. Keller
sfkeller at hsr.ch
Wed Jul 31 19:28:23 EDT 2002
Frank,
Frank Warmerdam wrote:
> Shapefiles have a lot going for them as far as being
> ubiquitous, easy to access very efficiently, generally
> simple and a reasonable set of geometric types for most
> GIS purposes. On the downside they lack internal metadata,
> coordinates systems, and representation information. Also
> as you point out xbase is sucky in a number of respects.
>> Aren't we the "parents" who can define ourselves what
>> is "native"
>> to Mapserver?
> Shapefiles are "native" because that is the mechanism that Steve has
> fine tuned for maximally efficient access. Both OGR and PostGIS
> access slower due to extra layers of abstraction, and data
> structure conversion going on (even OGR on Shapefiles). We could
> develope a new "native" format for MapServer that is as fast as
> shapefiles, but what exactly would it offer that shapefiles don't?
Simply put: That's all the advantages of a system-neutral XML-format which are
well summarized in the OGC presentation of GML. Specifically it's mainly the
*backend* you mentioned; but also this:
A common well known "more universal" (XML) data structure would give more
possibilities as well as a fair chance to the free market for other GIS. This
will most probably result in more and better functionality of the GIS
supporting Mapserver as well of Mapserver itself.
Therefore: Why not take GML 3 (zipped and/or indexed)?
>> So, what I still want to evaluate is, if a sequential (binary)
>> file object stream to Mapserver (perhaps via OGR as zipped XML)
>> is faster and more flexible in querying than a comparable
>> (possibly indexed) object stream from PostgreSQL?
> Hmm. A bit hard to answer.
Let me explain:
* I assume that a sequential file object stream (import online
via OGR) is faster (unindexed at least for a full zoom)
than an object stream from PostgreSQL (import offline
via PostgreSQL-Loader).
* But for data analysis PostgreSQL would be more efficient
and of course more flexible than a file object stream.
So, importing an XML file into PostgeSQL would provide
both graphic (Mapserver) as well as data anylysis
(PostgeSQL) access with the same implementation effort.
That's my short-term performance/flexibility-dilemma!
Best regards,
- Stefan Keller
