[mapserver-users] Easy Mapserver demo (was: New User)
Puneet Kishor
pkishor at GeoAnalytics.com
Sun Jun 2 22:31:32 EDT 2002
On Sunday, June 2, 2002, at 04:57 PM, Stephen Woodbridge wrote:
> Nicolas,
> This sounds great! Give it a try and let us know how it works. I would
> suspect that you might have problems with needing a writable directory
> pn the hard disk for mapserver to dump images, etc. into, so you might
> need to some how configure a hard disk directory to be mapped into the
or you could just write the images out to STDOUT...
> web servers htdocs tree.
> -Steve
> Nicolas Boretos wrote:
>> Hi,
>> I've got a simple webserver and mapserver all packaged up that
>> basically
>> you click and run. I have not tried to run off a cd, but can give it a
>> shot if youd like. Let me know if you have any interest...
>> sincerely,
>> nicolas boretos
>> Tyler Mitchell wrote:
>>> A while back I had demoed a program that was a mini web server that
>>> could
>>> run straight off a cdrom. It included CGI support. Does this ring a
>>> bell
>>> with you? I'm trying to find this program again - any suggestions?
>>> I'd like to work with others to get Mapserver and related technologies
>>> working in such an environment for demostration purposes. Have you
>>> done
>>> any work on this sort of thing?
>>> Drop me if this sounds good to you or if you have any pointers for me.
>>> Tyler
>>> "Simon Kirkness"
>>> <Simon.Kirkness at fisheries.ns To:
>>> <mapserver-users at lists.gis.umn.edu>
>>> w.gov.au> cc:
>>> Sent by: Fax to:
>>> owner-mapserver-users at lists. Subject:
>>> [mapserver-users] New User
>>> gis.umn.edu
>>> 05/29/2002 05:41 PM
>>> Hi All,
>>> Am I able to run the MapServer application and Demo on a PC
>>> independant
>>> of a web server?
>>> Simon Kirkness
>>> NSW Fisheries
>>> Project Officer
>>> Threatened Species
>>> Port Stephens Fisheries Centre
>>> Ph: (02) 4916 3810
>>> Fax: (02) 4916 3880
>>> Email: kirkness at fisheries.nsw.gov.au
>>> Note: This message is intended for the addressee named and may contain
>>> confidential information. If you are not the intended recipient,
>>> please
>>> delete it and notify the sender. Views expressed in this message are
>>> those
>>> of the individual sender, and are not necessarily the views of NSW
>>> Fisheries.
>>> (See attached file: InterScan_Disclaimer.txt)
