AW: [mapserver-users] Mapplet - Force Zoomdir with image buttons
Nicole Bömeke
bon at ivv-aachen.de
Mon Jun 3 03:23:49 EDT 2002
Try to set the following parameters and submit the application:
<form>
<input type="hidden" name="program" value="[program]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="map_web_imagepath" value="[map_web_imagepath]">
<input type="hidden" name="map_web_imageurl" value="[map_web_imageurl]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="imgsize" value="800 500"> <!--
x=img.width y=img.height -->
<input type="hidden" name="mapsize" value="800 500"> <!--
<input type="hidden" name="zoomdir" value="1">
<input type="hidden" name="zoomsize" value="2">
<input type="hidden" name="imgxy" value="399.5 249.5"> <!--
x=(img.width-1)/2 y=(img.height-1)/2 -->
<input type="hidden" name="imgbox" value="-1 -1 -1 -1">
<input type=image src="/mapserv3.5_vrs_appl/images/zoomin.gif" width="38"
height="38" border="0" alt="Zoom In">
</form>
Nicole
Nicole Bömeke
IVV-Aachen
Germany
-----Ursprüngliche Nachricht-----
Von: owner-mapserver-users at lists.gis.umn.edu
[mailto:owner-mapserver-users at lists.gis.umn.edu]Im Auftrag von Marco
Catellani
Gesendet: Freitag, 31. Mai 2002 19:48
An: mapserver-users at lists.gis.umn.edu
Betreff: [mapserver-users] Mapplet - Force Zoomdir with image buttons
Hi all.
I'm using MapServer 3.6 with Mapplet Extension.
The question involves zoomdir value. Using classical interface with radio
button (coupled with the [zoomdir_-1|0|1_check] special character) the
application run correctly.
I'm trying to use image buttons instead of radio buttons to obtain the same
result. What I need is that clicking the image the zoomdir value change
correctly.
I'm using code like this:
function ZoominSub(){
document.mapserv.zoomdir.value = "1";
<input type="hidden" name="zoomdir" value="">
<a href="#" onClick="zoomin();">
<img src="http://localhost/images/zoomin.gif" alt="Zoom in"></a>
but I don't get what I want; in fact when I click the image and then I click
over the map the result is a pan operation, not a zoomin one.
Do you have any suggestion or advise?
Thank you very much!
Marco
