[mapserver-users] shapeObj mapscript comments
Puneet Kishor
pkishor at GeoAnalytics.com
Tue Jun 4 11:27:08 EDT 2002
you classify it in the map file... the scripts merely select, and
passthrough the matching values...
so, you say...
CLASSITEM blah
CLASS
EXPRESSION ([blah] > 30 and [blah] < 40)
the scripts just do their mechanical stuff... such as
setexpression("/$expr/") or draw()
hope this is what you were asking about.
On Tuesday, June 4, 2002, at 09:06 AM, imap at chesapeake.net wrote:
> ok guys... using perl mapscript, still trying to fix
> a bunch of broken code after going to mapserv3.5,
> somewhere along the line
> shapeObj->draw(mapObj,layerObj,image,integer class_index,character text)
> changed to
> shapeObj->draw(mapObj,layerObj,image)
> My question here is... How do you classify the shape based on the
> classes
> defined for layerObj? the shapeObj->draw() method is missing
> attributes,
> so any clue how to get around this?
> Regards,
> Chris Stuber (mapsurfer)
> Silicon Mapping Solutions
