[mapserver-users] Re: [postgis-users] sql works, but not
as layer?
Twan Kogels
twan at twansoft.com
Tue Jun 4 15:57:03 EDT 2002
I'm sorry, but after tons of trying and recreating tables it still doesn't
work. I've simplyfied the query:
CONNECTION "user=postgres dbname=food host=10.0.0.2"
DATA "the_geom from (SELECT * from objecteigenschappen o left join
pc6punten p on p.pc6=o.eigenschap_3) as foo"
FILTER "pc6 like '1797%'"
I still get the postgresql error "ERROR: Attribute 'oid' not found", but i
have defined a index for oid for both (pc6punten en objecteigenschappen)
tables. Also geometry_columns table is correctly setup.
Does anybody knows what is going wrong?
Best regards,
-twan
> > DATA "the_geom from objecteigenschappen o left join pc6punten p on
> > p.pc6=o.eigenschap_3"
> > FILTER "(the_geom && GeometryFromText('BOX3D(109258 559953,115258
> > 565953)'::box3d,-1) and distance(the_geom, GeometryFromText('POINT(112258
> > 562953)',-1)) < 3000)"
>You're using the DATA parameter incorrectly - its a bit confusing.
>The generic templates are:
>DATA "<geom column name> from <table name>"
> or
>DATA "<geom column name> from (<sql statement>) as foo"
>In your case, use:
>hope that works,
>dave
http://www.twansoft.com
