[mapserver-users] PHP / Mapscript AccessViolation
Hankley, Chip Chip.Hankley at GASAI.Com
Tue Jun 4 17:08:17 EDT 2002
Robert...
Make sure you are using the most current version of the php_mapscript dll. I
know that I was having a similar problem some time ago, and that a bug was
later found and fixed by the guys at DM Solutions.
You might consider upgrading to the 3.6 dev version. This runs under PHP
4.1.2 and, I believe, is fairly stable (I haven't had any problems with
it...)
Cheers!
Chip
-----Original Message-----
Sent: Tuesday, June 04, 2002 3:19 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] PHP / Mapscript AccessViolation
Hello,
I'm using MS 3.5, PHP4.06, Php_Mapscript_35.dll and Apache at office and
there is no problem, the same code and data don't work at home, using the
same components (also enabled is php_dbase.dll)
The error occurs only, if I do an "infoclick" at an Object, there is no
problem to zoom or pan.
I don't know exactly, at which point the script fails.
The first message:
OleMainThreadWndName-php.exe - error in application:
The instruction in "0x00e2ebf0" refer to memory at "0xca3d097a". The process
"Read" could not carry out on the memory.
If I use then the debugger I get the error message:
Access Violation in php.exe (PHP_Mapscript_35.dll).
I think, something is not well configured at home, but what?
Robert
robert fritz
ruhwaldstraße 12
16540 hohen neuendorf
robert.fritz at rz.hu-berlin.de
robert.fritz at epost.de
robert-fritz at web.de
