[mapserver-users] problems with mapscript java on linux
Tobias Zügel
zuegelts at studi.informatik.uni-stuttgart.de
Wed Jun 5 05:05:28 EDT 2002
I built mapscript (from mapserver 3.6) java on debian (IBM Jdk 1.3.1,
SWIG 1.3.11u).
Building process works fine; only a few warnings though ...
I afterwards copied the library and the classes to the appropriate
locations and tried to write my first program, which is attached below.
It compiles just fine, but i get the following output:
# java demo
Trying to load mapscript ...
successful!
Unexpected exception has occurred:
ReportedExceptionCode = b, at ExceptionAddress = 41e34310
ACCESS_VIOLATION occured outside Interpreter and JITed code
ExecMode = EXECMODE_BYTECODE
stackpointer=0xbffc7370
Writing Java core file ....
Written Java core to javacore.txt
When I look inside javacore.txt i find the following:
"main" (TID:0x100519D8, sys_thread_t:0x8058B68, state:R, native
at edu.umn.gis.mapscript.mapscript.mapObj_draw(Native Method)
at edu.umn.gis.mapscript.mapObj.draw(mapObj.java:267)
at demo.main(demo.java:19)
What is wrong here? Any suggestions?
Greetings,
Toby
----------------------snipp------------------------------------------------
import java.io.*;
import java.util.*;
import edu.umn.gis.mapscript.*;
class demo {
static public void main (String args[]) {
try
System.out.println("Loading library ...");
System.loadLibrary("mapscript");
System.out.println("successful!");
catch (UnsatisfiedLinkError e)
e.printStackTrace();
mapObj map = new mapObj("/var/www/mapserver/demo.map");
imageObj image = map.draw();
image.saveImage("/var/www/mapserver/tmp/demo.png",mapscript.get_MS_PNG(),1,1,0);rip
\ / ASCII Ribbon Campaign / In the beginning was
X Against HTML mail / the word, and the word
/ \ and postings / was content-type: text/plain
