[mapserver-users] Web Server Tricks... Kind of Off Topic
Obe, Regina DND\MIS robe.dnd at CI.BOSTON.MA.US
Wed Jun 5 17:26:20 EDT 2002
You can also do the same thing with the built-in ASP XMLHttp or
ServerXMLHttp objects.  ServerXMLHttp is preferable for IIS.  The code is as
easy.  Not sure how the performance compares with commercial products.
To do it with the XMLHttp or ServerXMLHttp would be something like the below
'Set objhttp = Server.CreateObject("MSXML2.ServerXMLHTTP") (if you have this
installed)
Set objhttp = Server.CreateObject("Microsoft.XMLHttp")
' Opens the connection to the remote server.
With objhttp
	.Open "GET", "http://mapservername/scripts/mapserv?" &
Request.QueryString, False
	.Send
	Response.Write .ResponseText
End With
objhttp.ResponseText is the output of the page
-----Original Message-----
Sent: Wednesday, June 05, 2002 11:22 AM
To: Chip.Hankley at GASAI.Com; mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Web Server Tricks... Kind of Off Topic
Hi Chip,
Just to throw another idea into the mix...
A few years back I played around with a product called "ASPTear".  We had an
application running on an Intranet and wanted to put it on the Internet for
a few few users... but didn't want to open any additional ports other than
port 80 between the DMZ and the internal network.  Since the internal
servers weren't visible outside the DMZ, we set up the web server as
basically a relay station to our internal app and the only communication was
HTTP. I assume you're doing something similar?
Anyway... you simply create the asptear.dll object in your .asp and tell it
what "page" to grab... in this case it would be something like
asptear.getPage("http://mapservername/scripts/mapserv?" &
Request.QueryString)
and call it by...
http://slowservername/mapserver_relay.asp?template=blah&program=blah&etc
and it relays the resultant HTTP back to the client... it's almost as
painless on your web server as serving up a simple html page.  You'd just
have to remember that Mapserver will need to write the image to the
"visible" server so the client can access it through the URL.
This was a couple years ago and I think it was either freeware or
inexpensive shareware.  Just search on "asptear", if you can't find anything
let me know and I'll see if I can dig it up.
I think there are already better suggestions that have been made. But this
is something to look into if you're really in a bind and have no room for
flexibility in your server configurations.
>From: "Hankley, Chip" <Chip.Hankley at GASAI.Com>
>To: "MapServer List (E-mail)" <mapserver-users at lists.gis.umn.edu>
>Subject: [mapserver-users] Web Server Tricks... Kind of Off Topic
>Date: Tue, 4 Jun 2002 16:43:40 -0500
>I am by no means a guru at configuring / working out web server hardware /
>networking issues... and could use a little guidance.
>Our main webserver is pretty much a dog. We're running a 200 MHz dual
>processor server w/ win2K and IIS... it handles a number of things for our
>company (besides mapserver)... and it is S L O W (i know... 200 MHz,
>Win2K... big part of the problem).
>Anyway... my options are limited b/c of internal politics and the like - so
>Linux is out, as well as my own dedicated server.
>What I'm wondering is if there is some way to "pass-through" my mapserver
>requests to a more powerful box within the organization. For instance, a MS
>request would come in, and instead of being processed on that server, the
>actual mapserver work (the process of rendering the image from the raw GIS
>data) would occur on another more powerful machine, and then the image
>either would be passed back for service to the client, or would be read
>directly from that machine. Is such a thing possible? What would be the
>performance implications of such a trick?
>I think this is kind of how MO IMS and ArcIMS work in that there is a "Map
>Server" that runs as a service... not necessarily on the web server.
>TIA
>Chip Hankley
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
