[mapserver-users] Point Data
Steve Lime
steve.lime at dnr.state.mn.us
Fri Jun 7 02:20:20 EDT 2002
Assuming you're using the CGI version you *MUST* explicitly turn layers on using the layer or layers form variables if layers are not given a STATUS DEFAULT in the map file. The CGI application automatically turns all non-DEFAULT layers off when fired.
You have 3 options:
- add a control to the web app to allow the user to toggle that layer
- set STATUS DEFAULT
- add a hidden variable like <input type="hidden" name="layer" value="MACPERCH">
If you're not using the CGI version then we need more information to help solve the problem.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Simon Kirkness" <Simon.Kirkness at fisheries.nsw.gov.au> 06/06/02 21:24 PM >>>
Hi all,
I have managed to taylor the demo to display layers of interest and am
trying to display point data.
The layer will display when set on default but when is set to on or off
will not appear.
LAYER
NAME MACPERCH
TYPE POINT
DATA MACPERCH
STATUS ON
CLASS
NAME 'MACPERCH'
COLOR 128 255 164
SYMBOL 'CIRCLE'
SIZE 7
END
TOLERANCE 5
END
END
Any help would be appreciated
Regards
Simon Kirkness
NSW Fisheries
Project Officer
Threatened Species
Port Stephens Fisheries Centre
Ph: (02) 4916 3810
Fax: (02) 4916 3880
Email: kirkness at fisheries.nsw.gov.au
Note: This message is intended for the addressee named and may contain
confidential information. If you are not the intended recipient,
please
delete it and notify the sender. Views expressed in this message are
those
of the individual sender, and are not necessarily the views of NSW
Fisheries.
