[mapserver-users] Mapplet and Browsers
David Graham
dgraham at i3.com
Mon Jun 10 13:43:30 EDT 2002
Greetings Mapplet users:
I was wondering about peoples experience with use of the Mapplet with
different browsers.
I have been developing a new site. Currently only available on our
internal network. But I have found that I am having problems with
various Browsers hanging with use of the Mapplet applet. Now it may
simply be issues of browser configuration/maturity but I was wondering
what other peoples experience is.
IE 5.0.1 on Windows 2000 - Works
Mozilla 1.0 release candidate 3 on Windows 2000 - Hangs
Netscape 4.77 on Windows 2000 - Applet runs but does not load maps
Netscape 6.2 on Windows 2000 - Hangs
Mozilla 1.0 release candidate 3 on Linux - Hangs (Message is: Allocating
more space for read msg 816 )
Netscape 4.77.1 on Linux - Works
Netscape 6.2.3 on Linux - Hangs (Message is: Allocating more space for
read msg 806 )
Konqueror 2.1.1 on Linux - Fails with exceptions (see below)
The reason I bring this up is if I run against another applet like the
one at
http://www.crh.noaa.gov/radar/loop/DS.p19r0/si.kftg.shtml
Most everything works fine
IE 5.0.1 on Windows 2000 - Works Fine
Mozilla 1.0 release candidate 3 on Windows 2000 - Works Fine
Netscape 4.77 on Windows 2000 - Works Fine
Netscape 6.2 on Windows 2000 - Works Fine
Mozilla 1.0 release candidate 3 on Linux - Works Fine
Netscape 4.77.1 on Linux - Works Fine
Netscape 6.2.3 on Linux - Works Fine
Konqueror 2.1.1 on Linux - Runs applet does not display images
Now I tried hitting the Landview site also, and it has similar
problems. This is not surprising since I was using there compilation of
the mapplet.
I went to the MapServer web site and downloaded the mapplet.zip file
from the Utilities section and installed class files in the web server
but did not get any better results. I am currently unable to compile
them since I do not have the javascript package. But I wonder if that
is not where the problem is. Below is the Java Console Output form the
Konqueror web browser. The ClassFormatErrors occur right before it
hangs up. That has to do with the Javascript Object libraries.
Has anyone else been having or working on these problems? Any input
would be appreciated.
Dave Graham
Konqueror Java Console Output
Java VM version: 1.3.0
Java VM vendor: IBM Corporation
Unable to load JSSE SSL stream handler, https support not available
java.lang.ClassFormatError: netscape/javascript/JSObject (Bad magic number)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:496)
at
java.security.SecureClassLoader.defineClass(SecureClassLoader.java:117)
at
org.kde.kjas.server.KJASAppletClassLoader.findClass(KJASAppletClassLoader.java:314)
at
org.kde.kjas.server.KJASAppletClassLoader.loadClass(KJASAppletClassLoader.java:335)
at mapplet.init(mapplet.java:74)
at
org.kde.kjas.server.KJASAppletStub.initApplet(KJASAppletStub.java:145)
at org.kde.kjas.server.KJASAppletStub$1.run(KJASAppletStub.java:98)
at java.lang.Thread.run(Thread.java:498)
at
at
org.kde.kjas.server.KJASAppletClassLoader.findClass(KJASAppletClassLoader.java:289)
at
at
David W. Graham
Director of Geospatial Applications Development
information integration and imaging, LLC
201 Linden St, Third Floor
Fort Collins, CO 80524
(970) 482-4400
dgraham at i3.com
http://www.i3.com
