[mapserver-users] Thematic points by database values
Lowell Filak
lfilak at medinaco.org
Fri Jun 14 13:05:30 EDT 2002
You could set the value using mapscript and then assign the size:
$csize = 4 + $sql_query_result_array[0];
$class->{size_or_sizescaled} = $csize
However there's most certainly multiple ways to do it.
Lowell F.
The following message was sent by "Martin, Daniel" <DMartin at erac.com> on Fri, 14 Jun 2002 10:03:39 -0500.
> I am trying to add thematic points by a value in the database. Every
> example I've seen involves the use of many classes. I'd rather avoid that,
> because my point values have an undetermined range, and change often.
> I'm looking for something along the lines of:
> CLASS
> SIZE 4 + MyDbaseItem
> END
> But, I haven't found anything that works. Is it possible to do this?
> Thanks,
> Dan Martin
