[mapserver-users] Support for PNG Symbols
Referencia SA georef at tie.cl
Mon Jun 17 17:37:39 EDT 2002
Thanks Scott for kind reply, i am submitting the question again to the list
to see if some one else have a clue....
Hi every one
Finally we have mapserver running. We didn't install .gif support, only .png
installed.
 We are playing with itasca demo, and  have changed all .gif to .png  how
ever we get the following error:
 msLoadMap(): General error message. Undefined symbol "symbols/ctyhwy.png"
in class 0 of layer ctyrdln3_anno.
Can the symbols be .png or they must be .gif? If above possible, how to
avoid error?
Off course, if class for symbol is commented (#) the demo runs ...
 Juanse
 temuko-chile
> Juanse,
> I am not sure about these issues myself since we are just starting with
> the package also. We are using jpegs.
> Good luck with this topic.
> Sorry I cannot be of more help.
> Scott
> Referencia SA wrote:
> > Scott
> > Thanks, i have the example running "commenting out" the need section,
how
> > ever i would love to have the .png working, instead of the .gif images.
> > I understand that .png is the favoured format within linux.
> > So the question is still valid : can one use .png for symbol definition?
> > Juanse
> > ----- Original Message -----
> > From: Scott Davidson <davidson at usgs.gov>
> > To: Referencia SA <georef at tnet.cl>
> > Sent: Monday, June 17, 2002 10:21 AM
> > Subject: Re: [mapserver-users] mapserver 3.6 compile error
> > > I believe that you have to comment out the sections that use the
> > > .gif files, not just change the files extensions. Comment out the
> > > porrtion :
> > > LAYER
> > >   NAME ctyrdln3_anno
> > >   GROUP roads
> > >   MAXSCALE 300000
> > >   STATUS OFF
> > >   DATA ctyrdln3
> > >   TYPE ANNOTATION
> > >   LABELITEM "road_name"
> > > #  CLASS
> > > #    COLOR 255 255 255
> > > #    SYMBOL 'symbols/ctyhwy.gif'
> > > #    LABEL
> > > #      MINFEATURESIZE 40
> > > #      MINDISTANCE 150
> > > #      POSITION CC
> > > #      SIZE TINY
> > > #      COLOR 0 0 0
> > >     END
> > >   END
> > > And
> > > # Start of reference map
> > > #REFERENCE
> > > #  IMAGE graphics/reference.gif
> > > #  EXTENT 393234.393701263 5205405.16440722 495769.579718949
> > 5307959.02579127
> > > #  SIZE 120 120
> > > #  STATUS ON
> > > #  COLOR -1 -1 -1
> > > #  OUTLINECOLOR 255 0 0
> > > #END
> > > Then it should work.
> > > > Finally we have mapserver running. We didn't install gif support,
only
> > .png
> > > > installed.
> > > > how ever we get the following error:
> > "symbols/ctyhwy.png" in
> > > > If above possible, how to avoid error?
> > > > Juanse
> > > > temuko-chile
