[mapserver-users] Join labels and attribute query
Steve Lime
steve.lime at dnr.state.mn.us
Tue Jun 18 16:51:06 EDT 2002
MapServer supports this using the TEXT expression parameter in a CLASS
object. You'd write this as:
TEXT ([ZAEHLER], [NENNER])
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Matthias Scholz <matthias.scholz at vgem-klostermansfeld.de> 06/18/02
06:42AM >>>
Hello
> Part 1: LABELITEM "ZAEHLER,NENNER" should at least stack the labels
so if you
> had a field SLASH you could LABELITEM "ZAEHLER,SLASH,NENNER"
If i try this, then i get an error message: msDBFGetItemIndex(): "DBASE
file
error. Item 'ZAEHLER,NENNER' not found." And this logical, if you look
in the
source. I use mapserevr 3.6
> Part 2: EXPRESSION ('[GEMARKUNG]' eq 'abc' AND FLUR = 1 AND ZAEHLER =
1000
> AND NENNER = 10)
OK, but i need a dynamic query from a HTML form?
Matthias Scholz
> Lowell F.
> The following message was sent by Matthias Scholz
> <matthias.scholz at vgem-klostermansfeld.de> on Mon, 17 Jun 2002
15:15:49
> +0200.
> > Hello,
> > how can i join two or more labels and display it at once? I use
shape-files
> as
> > data. In the dbf-file i have the following attributes: ID,
RECHTSWERT,
> HOCHWERT,
> > DATUM, FOLIE, OBJART, ALIASFOLIE, ALIASART, ALK-NR, GEMARKUNG,
FLUR,
> ZAEHLER,
> > NENNER
> > For this Layer i need an annotation in the form: "ZAEHLER/NENNER"
This is
> the
> > notation in german "Flurkarten". In the dbf-file i cannot join this
two
> columns,
> > because the converter for the shape-files writes the files and the
slash
> between
> > ZAEHLER and NENNER is important. I have try it, but i can only view
one
> > annotation :-(
> > My second problem is how i can make a query with with attributes?
In a html
> form
> > i have the fields GEMARKUNG, FLUR, ZAEHLER, NENNER. Together are
this
> four
> > attribues uniqe in the dbf-file. Is it possible to make a query
with more
> than
> > one attribute?
> > Thanks for help!!!
> > Matthias Scholz
> > : Verwaltungsgemeinschaft Klostermansfeld :
> > : Kirchstr. 1 :
> > : 06308 Klostermansfeld :
> > : Telefon: (+49) 034772/800 :
> > : Telefax: (+49) 034772/80200 :
> > : eMail: info at vgem-klostermansfeld.de :
> > : WWW: http://www.vgem-klostermansfeld.de :
> > Diese eMail wurde mit IMP 3.0 gesendet (http://www.horde.org)
: Kirchstr. 1 :
