[mapserver-users] Join labels and attribute query
Ryan, Adam
ARyan at co.linn.or.us
Tue Jun 18 19:15:07 EDT 2002
But Part 2 is not a query, is it? It's just a class expression. What if
you want the query results for that expression?
Adam
-----Original Message-----
Sent: Monday, June 17, 2002 8:16 AM
To: Matthias Scholz; mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Join labels and attribute query
Part 1: LABELITEM "ZAEHLER,NENNER" should at least stack the labels so if
you had a field SLASH you could LABELITEM "ZAEHLER,SLASH,NENNER"
Part 2: EXPRESSION ('[GEMARKUNG]' eq 'abc' AND FLUR = 1 AND ZAEHLER = 1000
AND NENNER = 10)
Lowell F.
The following message was sent by Matthias Scholz
<matthias.scholz at vgem-klostermansfeld.de> on Mon, 17 Jun 2002 15:15:49
+0200.
> Hello,
> how can i join two or more labels and display it at once? I use
shape-files as
> data. In the dbf-file i have the following attributes: ID, RECHTSWERT,
HOCHWERT,
> DATUM, FOLIE, OBJART, ALIASFOLIE, ALIASART, ALK-NR, GEMARKUNG, FLUR,
ZAEHLER,
> NENNER
> For this Layer i need an annotation in the form: "ZAEHLER/NENNER" This is
the
> notation in german "Flurkarten". In the dbf-file i cannot join this two
columns,
> because the converter for the shape-files writes the files and the slash
between
> ZAEHLER and NENNER is important. I have try it, but i can only view one
> annotation :-(
> My second problem is how i can make a query with with attributes? In a
html form
> i have the fields GEMARKUNG, FLUR, ZAEHLER, NENNER. Together are this four
> attribues uniqe in the dbf-file. Is it possible to make a query with more
than
> one attribute?
> Thanks for help!!!
> Matthias Scholz
> : Verwaltungsgemeinschaft Klostermansfeld :
> : Kirchstr. 1 :
> : 06308 Klostermansfeld :
> : Telefon: (+49) 034772/800 :
> : Telefax: (+49) 034772/80200 :
> : eMail: info at vgem-klostermansfeld.de :
> : WWW: http://www.vgem-klostermansfeld.de :
> Diese eMail wurde mit IMP 3.0 gesendet (http://www.horde.org)
