[mapserver-users] Mapsever 3.6, CGI Error
Martin, Daniel DMartin at erac.com
Fri Jun 21 10:45:44 EDT 2002
I'm assuming you are using Windows.  If not, disregard this message.
This happens on Windows if you didn't download the secondary package and
install the appropriate files into your C:\WINNT\SYSTEM32 (or other system
directory depending on your OS).
Go to the Win32 Binaries page,
http://mapserver.gis.umn.edu/win32binaries.html. If you downloaded one of
the first two links it mentions you also need libwww_dll.zip, and if you
downloaded one of the next two links you need ms35_libs.zip.  These are the
"secondary packages" I am talking about.
-Dan
-----Original Message-----
From: AntleN at DFO-MPO.GC.CA [mailto:AntleN at DFO-MPO.GC.CA]
Sent: Friday, June 21, 2002 7:19 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] Mapsever 3.6, CGI Error
Hi All,
  Using mapserver 3.5 and WMS version 1.1.0 my mapping application works
great.  However, when I tried to upgrade to Mapserver version 3.6, I got the
following error when I tried to generate a map.
"CGI Error The specified CGI application misbehaved by not returning a
complete set of HTTP headers. The headers it did return are:"
I am assuming that the WMS url calls should be no different. Perhaps there
are changes that I should make to the mapfile.
Any help on this matter would be greatly appreciated.
Thanks,
Natasha
