[mapserver-users] Mapscript/Java
Sathiskumar Govindasamy
gsathis at hashprompt.com
Fri Jun 21 11:39:01 EDT 2002
Isabelle,
The following is a mail that I have written to mapserver-users group a
while ago. I believe it might help. Also there is an example java
program of how to use it.
Thanks
Sathis
This is what I did.
I got the mapserver source code and untarred it and did the following
./configure --with-jpeg --with-gd --with-proj
--with-gdal=/usr/local/bin/gdal-config
make
Then I got the SWIG Version 1.3.11 source.
./configure --with-javac=/usr/java/j2sdk1.4.0/bin/
--with-java=/usr/java/j2sdk1.4.0/bin/
--with-javaincl=/usr/java/j2sdk1.4.0/include/
make
make install
I created a directory called java in mapserver-src/mapscript and created
a symlink for mapscript.i inside it. (In the new nightly builds, you
might not need this step since it should be already in there)
/usr/local/bin/swig -java -shadow -package mapscript mapscript.i
It created some java files.
Then I did
FLAGS="-DUSE_PROJ -DUSE_PROJ_API_H -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_WBMP -DUSE_GD_FT -DUSE_WMS -DUSE_TIFF -DUSE_JPEG -DUSE_EPPL
-DUSE_GDAL"gcc -fpic -c $FLAGS -I/usr/java/j2sdk1.4.0/include
-I/usr/java/j2sdk1.4.0/include/linux mapscript_wrap.c
gcc -fpic -shared -o libmapscript.so -L/usr/lib -lgd -ljpeg -lfreetype
-lpng -lz -ltiff -L/usr/local/lib -lgdal.1.1 -lproj mapscript_wrap.o
../../libmap.a
Java programs didn't compile right off the bat. I need to correct all
those 'long' variable types and return types. Then it compiled. (New
nightly build should compile clean)
In tomcat, I added the following line in /etc/tomcat4/conf/tomcat4.conf
export LD_LIBRARY_PATH=/opt/mapserver/mapscript/java:$LD_LIBRARY_PATH
I have the mapserver installed on /opt/
I have attached a servlet sample .
Thanks
Sathis
import javax.servlet.*;
import javax.servlet.http.*;
import java.io.*;
import java.util.*;
import mapscript.*;
public class demo extends HttpServlet
static
try
System.loadLibrary("mapscript");
System.err.println("Loaded the Mapscript library");
catch (UnsatisfiedLinkError e)
e.printStackTrace();
public void doGet(HttpServletRequest req, HttpServletResponse resp)
throws ServletException, IOException
System.err.println("doGet Method Accessed");
String strTruckID = req.getParameter("trucklocid");
mapObj map = new mapObj("/var/tomcat4/webapps/fleetmanager/nationalatlas/demo.map");
long image = map.prepareImage();
layerObj layerstate = map.getLayerByName("statesp020");
layerstate.draw(map.getCPtr(),image);
layerObj layerroad = map.getLayerByName("roadtrl020");
layerroad.draw(map.getCPtr(),image);
layerObj layerwater= map.getLayerByName("hydrogp020");
layerwater.draw(map.getCPtr(),image);
layerObj layercities= map.getLayerByName("cities");
layercities.draw(map.getCPtr(),image);
String filename = "temp/temp.jpg"
//msSaveImage(img,filename,type,transparent,interlace,quality)
mapscript.msSaveImage(image,"/var/tomcat4/webapps/fleetmanager/"+filename,map.getImagetype(),
map.getTransparent(),map.getInterlace(),map.getImagequality());
resp.sendRedirect(filename);
Isabelle KERVELLA wrote:
>In the documentation there is mentioned that the MapServer system
>supports MapScript which allows Java to access the MapServer C API.
>The MapServer 3.6 distribution includes PHP/Mapscript. But where can I
>find Java/Mapscript for Windows and Unix ?
>Or, is it possible to easily generate a java version of MapScript ?
>Thanks for any help,
>Isabelle
