[mapserver-users] Mixed Mapfile and Mapscript (php)
Yewondwossen Assefa
assefa at dmsolutions.ca
Mon Jun 24 10:05:35 EDT 2002
Hi There,
The way to set the colors in mapscript is :
* add a color in the map object : $colorindex = $map->addcolor(r, g, b)
* use the color index in your class setting : class->set("color",
$colorindex)
Hope it helps,
Erich Schroeder wrote:
> Hi,
> I'm trying to set up a php mapscript application in which I have a
> standard bunch of base layers in a standard base file (these draw just
> fine) but then I want to dynamically add additional point layers which are
> based on what shapefiles are present. I was wondering if anyone has some
> example code for what is needed for adding in and displaying a new layer?
> I'm probably missing something simple that I will find right after I send
> this, but the current code looks like:
> $map = ms_newMapObj("base.map");
> //find what files are present in the folder for a particular taxon
> $AgesPresent = GetAges($Taxon);
> //set some path stuff
> $TaxonPath = "$FaunmapPath/data/$TaxonLower";
> foreach ($AgesPresent as $key=>$age) {
> $layer = ms_newLayerObj($map);
> $layer->set(data,"data/$taxon/$age.shp");
> $layer->set(name,$age);
> $layer->set(type,"point");
> $layer->set(classitem,"sitenum");
> $layer->set(status,"MS_DEFAULT");
> $class = ms_newClassObj($layer);
> $class->set(name,strtoupper($age));
> $class->set(symbol,"circle");
> $class->set(size,7);
> $class->set(color,"7 27 249");
> $img = $map->draw();
> $url = $img->saveWebImage(MS_PNG, 0, 0, 0);
> printf("<img src=%s width=%d height=%d>\n", $url, $map->width,
> $map->height);
> It seems to correctly add the layers (numbering in 1-15 depending on the
> taxon), but I'm not seeing it. I'm sure that there is something wrong with
> the color setting, and I suppose I need a "draw" statement, but I don't
> see a clear description in any of the documentation or examples I have
> found so far.
> Erich
> Erich Schroeder Phone: (217)785-0033
> Curator, Information Technologies FAX: (217)785-2857
> Illinois State Museum GIS Lab email:erich(at)illinois.state.museum
> http://illinois.state.museum/
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
