[mapserver-users] php/Mapscript query
Steven Bowden
steveb at bundaberg.qld.gov.au
Tue Jun 25 22:02:44 EDT 2002
Hi List,
Hopefully somebody can point me in the right direction.
I am using mapserv 3.6.0 and php/mapscript with php 4.1.2 as CGI.
I am having trouble with the processquerytemplate method.
I can get it to process a layers template when the template is a file
but when the template is a URL I get nothing returned. I would assume
that I am meant to get the template URL back as a string with the
specified tags replaced with their actual value. Have I got the layer
set up correctly? Am I calling it correctly in php?
##### Layer #######
LAYER
NAME parcels_shaded
GROUP cadaster
CONNECTIONTYPE postgis
CONNECTION "user=gis dbname=blis host=blis"
TYPE polygon
STATUS on
MAXSCALE 9999
DATA "geom from bucc"
LABELITEM "tag"
HEADER parcels_header.html
FOOTER parcels_footer.html
TEMPLATE "parcels.html"
#TEMPLATE
"http://blis/blis/action.php?action=query&value=[tag]&image=[img]"
CLASS
Name "Parcels"
COLOR 0 128 0
END
END
#### Php ########
$queryresult = $map->queryByPoint($query_point,MS_SINGLE,5);
echo $queryresult . "<br>";
$queryimg = $map->drawquery();
$query_url=$queryimg->saveWebImage(MS_PNG,1,1,0);
$queryarray["test"] = "steve";
$template = $map->processquerytemplate($queryarray);
echo "<hr>";
echo $template;
echo "<hr>";
Even though the [tag] tag isn't in the queryarray that gets passed to
processquerytemplate, it still substitutes the correct values into the
template file, I just had to pass something to it to get it to work.
The commented out template line in the layer doesn't return anything
where the uncommented template does.
Any help would be greatly appreciated.
Thanks
Steve
Steven Bowden
GIS Officer
Bundaberg City Council
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020626/a954fe3b/attachment.html
