[mapserver-users] Compiling Mapserver 3.6 for Linux (SuSE8.0)
David Turover dturover at student.santarosa.edu
Wed Jun 26 10:58:09 EDT 2002
On Wed, 26 Jun 2002, Peter Haussl wrote:
> I try to compile mapserver for Linux (Distribution: SuSE 8.0) to run with
> Proj 4.4.5
> GD 1.8.3 (including GIF Support)
> LibPNG 1.2.3
[snip]
> while doing the make i've got the following errormessages
> make: yacc: Command not found
> make: *** [mapserver.c] Error 127
Sounds like you're missing the "yacc" program, or its location is not in
your $PATH environment variable. yacc is one of the development tools
used to build mapserver. If you can't find it on your system, try this:
ftp://ftp-linux.cc.gatech.edu/pub/linux/distributions/suse/suse/i386/8.0/suse/d2/yacc-91.7.30-524.i386.rpm
Good luck!
