[mapserver-users] Mapscript/Java/Servlet users: give this a whirl...
C F
gis_consultant at hotmail.com
Wed Jun 26 12:19:59 EDT 2002
I've been having this very unusual problem running servlets and mapscript.
As far as I can tell, it's working great except under one condition. If a
user submits a request to the servlet, then hits the browser's refresh
button before the his/her previous one is finished, it *crashes* my servlet
engine. This only happens if I'm executing imageObj.draw() somewhere in it
*and* trying to print a response back to the client. If I don't do anything
with my HTTPServletResponse object, I can hit refresh as many times as I
want as fast as I want with no problems. Anyway, without getting too deep
into the issue, etc. I would be grateful if someone else could try doing
this.
Submit a request to your servlet that draws a map and saves out to an image
(one that takes at few seconds or more).
Then hold your <CTRL> key down (to make sure it refreshes) and hit your
refresh button a few times fast while your first request is still pending.
Sometimes it'll keep showing you the cached page after the servlet engine
has crashed. So after that, try moving to another page being served by your
servlet engine, or change your url params or just somehow check to make sure
it actually *is* running.
I'd like to hear your results.
Here's my environment.....
Linux 7.3
Tomcat 4 (standalone)
JDK 1.4 (J2SDK)
MapServer version 3.6.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
INPUT=POSTGIS INPUT=SHAPEFILE
My data is all in PostGIS
Another note... I also tried this with Tomcat 3 and JDK 1.3... same results.
Also note that this problem *only* occurs with concurrent requests from the
*same* browser. I can hit it at the same time with several different
browsers with no problems.
Thank you
_________________________________________________________________
Chat with friends online, try MSN Messenger: http://messenger.msn.com
