[mapserver-users] mapserv running problem
Hao Ding
hdi12 at it.canterbury.ac.nz
Wed Jun 26 21:24:26 EDT 2002
Hi Tyler,
My configure command is
./configure --with-gd=$HOME/local --with-proj=$HOME/local
The gd and proj lib and include files are installed in my $HOME/local
directory.
Cheers,
Hao
>===== Original Message From Tyler Mitchell <TMitchell at lignum.com> =====
>Hi Hao, could you tell us what options/libraries you are compiling it with?
>What do you add to the ./configure command?
>| | Hao Ding |
>| | <hdi12 at it.canterbury.ac.nz> |
>| | Sent by: |
>| | owner-mapserver-users at lists.|
>| | gis.umn.edu |
>| | 06/25/2002 09:41 PM |
> | To: mapserver-users at lists.gis.umn.edu
> | cc:
> | Fax to:
> | Subject: [mapserver-users] mapserv running problem
>Hi,
>I am a new mapserver user. I successfully compiled mapserver 3.6.0
>together
>with proj.4, but got message "Internal Server Error" when running
>'mapserv'.
>The error info in the err.log file is
>[Wed Jun 26 16:19:35 2002] [error] [client 132.181.14.150] Premature end of
>script headers: /home/cosc/studPG/hdi12/apache2/cgi-bin/mapserv
>If I do not compile mapserver with any library (simply use './configure'
>and
>'make'), the 'mapserv' was running well.
>Can anyone explain the problem and how to solve?
>Regards
>Hao
