[mapserver-users] Java Mapscript and Tomcat
C F
gis_consultant at hotmail.com
Thu Jun 27 11:49:45 EDT 2002
Hi Andreas,
Have you been reading my thread today and yesterday about Mapscript and
Java? It doesn't answer your specific question here, but it might save you
some of the effort until that issure of Tomcat crashing gets resolved...
unless you have ideas on how to fix it. Because, in my mind, it basically
rules out Java Mapscript as an option for production usage if it's so easy
to crash the servlet engine. Hopefully somebody out there has the answer
and just hasn't chimed in yet :)
Anyway, about your question... I haven't tried to do what you're doing.
I've had so many issues with this stuff that, just to make sure I rule out
other factors, I've restarted Tomcat every time I made changes.
>From: "Andreas Hirner" <andreas_hirner at hotmail.com>
>To: mapserver-users at lists.gis.umn.edu
>Subject: [mapserver-users] Java Mapscript and Tomcat
>Date: Thu, 27 Jun 2002 14:33:36 +0200
>Hello,
>recently I have started developing servlets using Java Mapscript. I use
>Linux as OS and Tomcat as servlet engine. But the development process is
>severely hampered by the fact that I have to restart Tomcat every time
>after
>making changes to the servlet. If I only reload the application using the
>manager tool, the native Mapscript library is loaded a second time and
>causes an error.
>I tried to write a class , which loads the library and put it in the
>common/lib directory in order avoid multiple loading of the library, but
>this does not work.
>Does anyone have some hints?
>Thanks in advance
>Andreas
>_________________________________________________________________
>Send and receive Hotmail on your mobile device: http://mobile.msn.com
Chat with friends online, try MSN Messenger: http://messenger.msn.com
