[mapserver-users] php_mapscript.so not found
Daniel Morissette morissette at dmsolutions.ca
Mon Mar 4 15:53:54 EST 2002
Pushkar Pradhan wrote:
> Hi,
> I compiled php_map***.so and placed it under the lib dir. of php.
> I've enabled dl in my .ini file and the extension_dir = ./
Setting 'extension_dir = ./' means that PHP should look for
php_mapscript.so in the directory where your php script lives.
If you placed php_mapscript.so in some lib dir (e.g. /usr/lib/php4) then
you should set extension_dir to point to that location:
  extension_dir = /usr/lib/php4/
Daniel
> I've compiled php as a dynamic module, I am running apache 1.3.22 , php
> 4.0.6, mapserver 3.5 on sun solaris.
> I also made user I've the path from my hello.php (which is trying to load
> the module) to the .so r-x for public. (this is suggested on MS website)
> Yet I get the foll. error:
> Warning: Unable to load dynamic library './php_mapscript.so' - ld.so.1:
> /rstc/user1/erc/pushkar/apache_1.3.22/bin/httpd: fatal:
> ./php_mapscript.so: open failed: No such file or directory in
> /rstc/user1/erc/pushkar/gis/hello.php on line 20
> I have done everything from restarting apache to opening a new browser.
> On opening hello.php in my browser I see extension_dir = ./ in the tables
> and so does everything else seem okay.
> If anybody has worked around this problem please help me.
> Thanks in advance,
> PUSHKAR S. PRADHAN
> Research Assistant
> MISSISSIPPI STATE UNIVERSITY,
> STARKVILLE, MS 39759.
> Engineering Research Center
> Box 9627
> Mississippi State, MS 39762-9627
