Fw: [mapserver-users] Error with mspostgisopenlayer
giorgio giorgio19291 at inwind.it
Tue Mar 5 06:10:46 EST 2002
----- Original Message -----
To: Obe, Regina DND\MIS
Sent: Tuesday, March 05, 2002 12:09 PM
Subject: Re: [mapserver-users] Error with mspostgisopenlayer
How I can compile the php mapscript with postgis support?
Is not sufficient insert the option for postgis in configure of mapserver??
Many thanks in advance.
Giorgio.
  To: 'giorgio' ; MAPSERVER (E-mail)
  Sent: Monday, March 04, 2002 10:11 PM
  Subject: RE: [mapserver-users] Error with mspostgisopenlayer
  Sounds like your PHP mapscript dll is not compiled with Postgis support.
    -----Original Message-----
    Sent: Monday, March 04, 2002 2:25 PM
    To: MAPSERVER (E-mail)
    Subject: [mapserver-users] Error with mspostgisopenlayer
    Hello to all,
    i have recieved this message on a my implementation  of mapserver with php-mapserver when I try to load a layer using postgis:
    "Warning: MapServer Error in msPOSTGISLayerOpen(): msPOSTGISLayerOpen called but unimplemented!in /var/www/html/probe/my.php on line 731
    Fatal error: Call to a member function on a non-object in /var/www/html/probe/my.php on line 732"
    this is strange because the same layer with a perl mapscript is loaded normally.
    Depend It from php mapscript??
    This is the last part of my Map.file only the last layer is not loaded.
    Any suggestion?? Thanks a lot in advance
    Giorgio.
    LAYER
    NAME aree
    TYPE LINE
    STATUS OFF
    DATA aree
    CLASS
    NAME "aree"
    COLOR 0 0 0
    END
    END
    LAYER
    CONNECTIONTYPE postgis
    NAME my
    CONNECTION "user=nobody dbname=sele host=192.168.0.1"
    TYPE LINE
    STATUS OFF
    DATA "the_geom from mio"
    CLASS
    NAME "my"
    COLOR 0 255 0
    END
    END # Layer
    END # Map File
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020305/7c97a93d/attachment.html
