[mapserver-users] Mapinfo TAB files and lcc projection
Ari Yakar ayakar at globvision.com
Fri Mar 15 15:27:20 EST 2002
Hi All,
I am trying to use simple Mapinfo TAB files (Map of Canada,capitals and
Highways) with Mapserver 3.5. If I don't
apply any projection there is no problem. However when I specify the
projection
settings, map loads with 40x zoomed in. I have to Zoom out to see the whole
map.
I checked documentation of proj3 and proj4 but can't figure out the proper
settings
The following is the PROJECTION settings I have in the map file.
PROJECTION
  "proj=lcc"
  "ellps=GRS80"
  "lat_0=60"
  "lon_0=-105"
  "lat_1=61.666666700"
  "lat_2=63.333333300"
  "datum=NAD83"
  "units=m"
END
I am attaching the Map file just in case it might help to identify the
problem.
Thanks
Ari Yakar
Globvision Inc.
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
#EXTENT -565918.875607 55035.833974 506926.040335 1264723.213684
EXTENT -180 -90 180 90
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter discussion
PROJECTION
  "proj=lcc"
  "ellps=GRS80"
  "lat_0=60"
  "lon_0=-105"
  "datum=NAD83"
  "units=m"
END
# Start of web interface definition (including WMS enabling metadata)
WEB
  HEADER demo_header.html
  TEMPLATE demo.html
  FOOTER demo_footer.html
  #MINSCALE 1000
  #MAXSCALE 1550000
  IMAGEPATH "d:\virtual\Mapserver\tmp\"
  IMAGEURL "/tmp/"
  LOG "c:\temp\DemoApp.log"
  METADATA
    WMS_TITLE "Server Demo"
    WMS_ABSTRACT "Sample Data"
    WMS_ACCESSCONSTRAINTS none
    # change this value to match your setup
    WMS_ONLINERESOURCE "http://192.168.1.22/demo/demo_init.html"
    WMS_SRS "EPSG:26915"
   END
END
QUERYMAP
  SIZE 200 200
  STATUS ON
  STYLE HILITE
  COLOR 255 0 0
END
# Start of reference map
REFERENCE
  IMAGE graphics/reference.gif
  #EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
  SIZE 120 120
  STATUS ON
  COLOR -1 -1 -1
  OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
  KEYSIZE 18 12
  LABEL
    TYPE BITMAP
    SIZE MEDIUM
    COLOR 0 0 89
  END
  STATUS ON
END
# Start of scalebar
SCALEBAR
  LABEL
    COLOR 255 255 255
    SIZE tiny
  END
  STYLE 1
  SIZE 80 2
  COLOR 255 255 255
  UNITS METERS
  INTERVALS 1
  TRANSPARENT TRUE
  STATUS TRUE
END
# Start of symbol definitions (we're only using a few)
SYMBOL
  NAME 'circle'
  TYPE ELLIPSE
  POINTS 1 1 END
  FILLED TRUE
END
# Start of layer definitions
# Layer 1
LAYER
  NAME Canada
  TYPE POLYGON
  STATUS ON
  CONNECTIONTYPE OGR
  CONNECTION "d:\MapserverData\eq\CANADA.TAB"
#  STYLEITEM "AUTO"
  CLASSITEM Province_Name
  CLASSITEM Pop_1990
  LABELITEM Province
 CLASS
    NAME "Ontario"
	EXPRESSION 'Ontario'
    COLOR 255 127 92
    OUTLINECOLOR  200 200 200
    TEMPLATE "resultL1.html"
  END
   CLASS
    NAME "Quebec"
	EXPRESSION 'Quebec'
	COLOR 195 209 186
  END
   CLASS
    NAME "1990 Pop (0 - 1M)"
	EXPRESSION ( ([Pop_1990] >= 0) and ([Pop_1990] < 1000000))
    COLOR 127 0 10
  END
   CLASS
    NAME "1990 Pop (1M - 2M)"
	EXPRESSION ( ([Pop_1990] >= 1000000 ) and ([Pop_1990] < 2000000))
    COLOR 127 100 50
  END
   CLASS
    NAME "1990 Pop (2M - 3M)"
	EXPRESSION ( ([Pop_1990] >= 2000000 ) and ([Pop_1990] < 3000000))
    COLOR 0  30 255
  END
   CLASS
    NAME "Canada"
    COLOR 0 127 92
  END
  HEADER "resultL1_header.html"
  FOOTER "resultL1_footer.html"
PROJECTION
	"AUTO"
END
END # Layer
# Layer 2
LAYER
  NAME Canhiway
  TYPE Line
  STATUS ON
  CONNECTIONTYPE OGR
  CONNECTION "d:\MapserverData\eq\Canhiway.TAB"
  STYLEITEM "AUTO"
  CLASSITEM Highway
  CLASS
    NAME "Canhiway"
    TEMPLATE "resultL2.html"
  END
  HEADER "resultL2_header.html"
  FOOTER "resultL2_footer.html"
PROJECTION
	"AUTO"
END
END # Layer
# Layer 3
LAYER
  NAME Can_caps
  TYPE point
  STATUS ON
  CONNECTIONTYPE OGR
  CONNECTION "d:\MapserverData\eq\Can_caps.TAB"
  STYLEITEM "AUTO"
  CLASSITEM Capital
  CLASS
    NAME "Can_caps"
    TEMPLATE "resultL3.html"
  END
  HEADER "resultL3_header.html"
  FOOTER "resultL3_footer.html"
PROJECTION
	"AUTO"
END
END
END # Map File
