[mapserver-users] Question concerning php-mapscript and frame(set)s and querybypoint method
Stephen Woodbridge woodbri at swoodbridge.com
Tue Mar 26 07:43:24 EST 2002
Peter,
I think what you have to do is use a javascript form validate on submit
function that determines if this is a query and then sets the
traget="results_frame_name" before doing the submit.
-Steve
Peter wrote:
> Hi Listers,
> got some kind of a fundamental question concerning php-mapscript and
> frame(set)s and querybypoint method.
> My map is part of a form as usual, but I do have some kind of result
> frame on the right side of my complete frameset (css).
> When I perform a querbypoint I get the results (dbase-records...), but
> I'd like to write the results to the right frame.
> Normally I would do that with the HTML Tag <form action> and so on.
> But, problem is that the map itself and the user-choices (pan, zoomIn,
> ZoomOut) are already a for handling the parameters for mapserver.
> Is there some kind of  HTML-TAG or any other soloution, that, within the
> phtml page, the results will be written to the frame on the right side?
> Is this possible with php or maybe with javascript?
> I appreciate every idea!
> Peter
