Bus error -- Re: [mapserver-users] Re: Perl/mapscript error
kenboss
kenboss at dilbert.dnr.state.mn.us
Fri May 3 15:56:32 EDT 2002
FWIW--
I have been experiencing variants of this problem as well -- I assume you folks
are using 3.6? My application dictates logic something like:
sub processData {
$map = new mapObj(undef);
$layer = new layerObj($map);
while (<INPUTFILE>) {
# do this that and the other
When I do that, I get the "Not a HASH" type errors. The script carries on, but
the results are all wrong.
If I rearrange my logic to something less reasonable like:
sub processData {
$map = new mapObj;
undef $map;
then my results come out right. I am not a perl guru, sorry, this is all I
know.
I had been discussing this with Steve Lime last week, but he's been traveling
this week, he'll be back at work next week. I wouldn't be surprised to see some
sort of resolution shortly thereafter... :)
--Ken Boss
Ken Boss
Digital Image Analysis / Web Stuff Forestry Resource Assessment
kenboss at dilbert.dnr.state.mn.us Minnesota Dept. of Natural Resources
Voice: 218 327 4449 ext. 237 413 SE 13th Street
Fax: 218 327 4517 Grand Rapids, MN 55744 USA
www.ra.dnr.state.mn.us
> > I think that an error in "eval( $perl )" results in an error
> > in the perl script whereas an error in "eval( "$perl" )"
> > results in an error in the eval and should not bomb the
> > script while "eval( $perl )" could bomb the script but
> > shouldn't in the case of "Not a HASH..." because it's just a
> > warning. More ellaboration on that may need to go to a perl list.
> > The source of all of this (which you've already identified)
> > is something that may need cleared up as Puneet suggests, if
> > it's creating that much of a problem.
> definitely needs to be cleared up. While I can apply patches Giorgio-style,
> that is definitely not a clean solution.
> in my case the script bombs completely. I wish I could correct this myself,
> but I am still teething as far as Perl is concerned. Perl fascinates me
> utterly and completely, but it will be a long while before I will come close
> to solving the above kind of problems.
> I don't know who the original author of Perl/Mapscript is... I am assuming
> it is Steve Lime. Any comments, Steve?
> pk/
> > Lowell F.
> > The following message was sent by Giorgio Volpe
> > <giorgio at nauta.it> on Thu, 02 May 2002 15:36:01 +0200.
> > > I've discovered, after many hours, that the problem is
> > related, in my
> > > case, to the fact that the sub raising the error on its
> > return (clean
> > > up) is called in an "eval" and the result of the call is
> > than stored as
> > > returned from eval ...
> > > @res=eval( $perl )
> > > after this, $@ contains "Not a HASH reference at
> > > /usr/local/lib/perl/5.6.1/mapscript.pm ..."
> > > if I change it to:
> > > @res=eval( "my \@r=$perl;return \@r" )
> > > error disappears!
> > > Is it a scope related problem? A little perl confusion?
> > > (if this can be of any neaning for someone, $perl contains a complex
> > > reference to an object that is in an other package ... like
> > > $me->{binded_obj}->method_causing_error() )
> > > Giorgio
