[mapserver-users] query points from database
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Tue May 14 05:32:09 EDT 2002
Joost,
> Is it possible to display points from a database? If so, how can they be
> queried for thier attributes?
You can do this using PostGIS/PostgreSQL and CGI mapserver. An alternative approach that
gives you lots of flexibility, however, would be to use MapScript in conjunction with your
database. The following example uses PHP/MapScript and the MySQL database. It only uses
one attribute (id) but by altering your query and placing the additional attributes in
the $points array you can get as much info as you want. Note that for clarity's sake I've
removed most of the error checking from the script.
$points = array(); # associative array to contain the point data
$dblink = mysql_pconnect("localhost", "user", "pass"); # connect to MySQL database
mysql_select_db("your_database"); # select database
$result = mysql_query('SELECT id,x,y FROM table'); # query database for x and y data
if (mysql_affected_rows($dblink) > 0) { # check to see if query produced output and
complain if it didn't
#iterate through results placing x y data in $points and associating it with
attribute id
while (($row = mysql_fetch_array($result, MYSQL_ASSOC))) {
$points[$row['id']]['x'] = $row['x'];
$points[$row['id']]['y'] = $row['y'];
} else {
die ('Query produced no output');
$mapObj = ms_newMapObj('yourmapfile.map'); # create a map object using your mapfile
$imageObj = $mapObj->draw(); # obtain an image object from the map
$layerObj = $mapObj->getLayerByName('points'); # get a layer object representing your point
layer (see mapfile snippet)
$classObj = $layerObj->getClass(0); # get a class object representing the first class in
the layer
$pointObj = ms_newPointObj(); # create a new point object to hold the X Y data
# iterate through the point data retreived from the database
foreach ($points as $id => $coordinates) {
$pointObj->setXY($coordinates['x'], $coordinates['y']); # set the X Y values of the
point object
$pointObj->draw($mapObj, $layerObj, $imageObj, 0, $id); # draw the point on the
image, using the id attribute to label it
$mapObj->drawLabelCache($imageObj); # draw the labels
$img_url = $imageObj->saveWebImage(MS_PNG, MS_FALSE, MS_FALSE, -1); # save the image to a
PNG file and obtain the url
print '<img src="'.$img_url.'" alt="Mapserver output" />'; # output the url for the image
# Mapfile snippet of points layer used in above code
LAYER
NAME points
TYPE POINT
STATUS ON
LABELCACHE ON
CLASS
OUTLINECOLOR 255 89 89
COLOR 255 136 136
SYMBOL 'circle'
SIZE 8
LABEL
ANTIALIAS true
FONT verdana
TYPE truetype
SIZE 8
COLOR 10 10 153
OUTLINECOLOR 199 216 252
POSITION auto
END
END
END
Good luck!
Homme Zwaagstra
