[mapserver-users] customize queries. (FWD)
E Perik erwin at perik.nu
Sat May 18 08:51:39 EDT 2002
Gerald,
regarding ths dropdown list:
Using PHP the following would produce a list of records of a specific
field:
* Place in html-section of a php-file *
<select name="ParkList" >
  <option>Select Item</option>
  <option>- - - - - - - - - - - - - - -</option>
  <?php GetDbaseValueList("YourLocation\\YourName.dbf", "YourFieldName")
</select>
* Place anywhere in a php-section *
// Get the data of a specified column of a .dbf database to a
option-list
function GetDbaseValueList($dbfname, $NameOfColumn)
   if ($db)
       dbase_close($db);
       $db = dbase_open($dbfname, 0);
  $row = dbase_numrecords($db);
  for ($i=1; $i <= $row; $i++)
     $rec = dbase_get_record_with_names($db,$i);
     $string = trim($rec[$NameOfColumn]);
     echo "<OPTION value=\"$i\">$string</OPTION>\n";
   dbase_close($db);
Now zooming to the object should be easy....
Erwin
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Thomas E.
Burk
Sent: zaterdag 18 mei 2002 3:54
To: mapserver-users at lists.gis.umn.edu
Cc: gerald80 at eudoramail.com
Subject: [mapserver-users] customize queries. (FWD)
------------- Begin Forwarded Message -------------
To: mapserver-info at lists.gis.umn.edu
Date: Thu, 16 May 2002 02:21:04 -0700
From: "gerald g villacarlos" <gerald80 at eudoramail.com>
Mime-Version: 1.0
X-Sent-Mail: off
Subject: customize queries.
X-Sender-Ip: 203.177.42.133
Content-Language: en
Content-Transfer-Encoding: 7bit
hello there, i got a question regarding inquery, i like to
customize my search using a list of predefined places in a
dropdown list,say example a list of towns are listed in a
dropdown list, when a particular user selects a particular town,
he is then zoom to that place, is it possible to do this?, what
are the things i need to add in my scripts?,
any suggestions or example.
thank you.
gerald
Join 18 million Eudora users by signing up for a free Eudora
Web-Mail account at http://www.eudoramail.com
------------- End Forwarded Message -------------
