[mapserver-users] PROJECTIONS WGS84 TMERC
Jaime Mejía
jomejia at main-task.com
Fri May 31 18:33:23 EDT 2002
The map's projection is tmerc
>Hello list,
>I've got a map in plain coordinates, datum:bogota
>(International Ellipsoid 1924, origin: 74d4.8550002'w, 4d35.9428332'n)
>And I've got GPS's points in WGS84.
>I want to display the GPS's points over the map with datum Bogota.
>My problem is that points seems to be 500mts displaced aprox.
>What sould I be doing wrong?
>My map definition:
>UNITS METERS
>PROJECTION
> "proj=tmerc"
> "a=6378388"
> "rf=297"
># "ellps=WGS84"
> "k=0.9996"
> "x_0=1000000"
> "y_0=1000000"
> "lon_0=74d4.8550002'w"
> "lat_0=4d35.9428332'n"
> "no_defs"
>END
>My GPS Layer definition:
>PROJECTION
> "proj=longlat"
> "ellps=WGS84"
># "units=dd"
>END
>Thanks in advance,
>Cordial Saludo,
>MAIN TASK
>Jaime Mejía Molina
>www.main-task.com
>Teléfono 3690760
>Móvil 2441490
>CL 28 # 35-67 of 204
>Bogotá D. C.
