[mapserver-users] Instalation problems...
Dragos Lipan
dlipan at pcrai.ro
Mon Nov 4 10:33:00 EST 2002
Jim Burnett wrote:
>Which version of GD do you have?
GD 2.0.4
>What linux distro?
RH 7.2
>-jim
>----- Original Message -----
>From: "Dragos Lipan" <dlipan at pcrai.ro>
>To: <mapserver-users at lists.gis.umn.edu>
>Sent: Monday, November 04, 2002 5:36 AM
>Subject: [mapserver-users] Instalation problems...
>>When trying to install mapserver 3.6.1,
>>after all necesary prerequisites,
>>I found for
>>./configure --with-gd=/usr --with-postgis --with-gdal --with-proj \
>> --with-ogr --with-wmsclient
>>the following
>>loading cache ./config.cache
>>checking for gcc... (cached) gcc
>>checking whether the C compiler (gcc ) works... yes
>>checking whether the C compiler (gcc ) is a cross-compiler... no
>>checking whether we are using GNU C... (cached) yes
>>checking whether gcc accepts -g... (cached) yes
>>checking for c++... (cached) c++
>>checking whether the C++ compiler (c++ ) works... yes
>>checking whether the C++ compiler (c++ ) is a cross-compiler... no
>>checking whether we are using GNU C++... (cached) yes
>>checking whether c++ accepts -g... (cached) yes
>>checking for ranlib... (cached) ranlib
>>checking for flex... (cached) flex
>>checking for yywrap in -lfl... (cached) yes
>>checking for bison... (cached) bison -y
>>checking if compiler supports -R... (cached) no
>>checking if compiler supports -Wl,-rpath,... (cached) yes
>>checking for exp in -lm... (cached) yes
>>checking how to run the C preprocessor... (cached) gcc -E
>>checking for ANSI C header files... (cached) yes
>>checking for strcasecmp... (cached) yes
>>checking for strncasecmp... (cached) yes
>>checking for strdup... (cached) yes
>>checking whether we should include JPEG support...
>>checking for jpeg_read_header in -ljpeg... yes
>> using libjpeg from system libs.
>>checking which version of GD to use...
>> using libgd from -L/usr/lib -lgd
>>checking where FreeType is installed...
>>checking for FT_Init_FreeType in -lfreetype... yes
>> using libfreetype -lfreetype from system libs.
>>checking where Zlib is installed...
>>checking for zlibVersion in -lz... yes
>> using libz from system libs.
>>checking where PNG is installed...
>>checking for png_init_io in -lpng... yes
>> using libpng from system libs.
>>checking for gdImageGif in -lc... no
>>checking for gdImagePng in -lc... no
>>checking for gdImageJpeg in -lc... no
>>checking for gdImageWBMP in -lc... no
>>checking for gdImageStringFT in -lc... no
>>checking for gdImageStringTTF in -lc... no
>>checking for gdImageString16 in -lc... no
>>checking for gdImageGifPtr in -lc... no
>> using GD ( -DUSE_GD_SWAP_XY) from /usr.
>>checking whether we should include PDF support...
>>checking for PDF_setlinewidth in -lpdf... no
>>checking for PDF_setrgbcolor in -lpdf... no
>>checking for PDF_moveto in -lpdf... no
>>checking for PDF_curveto in -lpdf... no
>>checking for PDF_show_xy in -lpdf... (cached) no
>> libpdf not found... PDF support not included.
>>checking whether we should include TIFF support...
>>checking for TIFFOpen in -ltiff... yes
>> using libtiff from system libs.
>>checking whether we should include EPPL7 support...
>> including EPPL7 support.
>>checking whether we should include PROJ.4 support...
>>checking for pj_init in -lproj... yes
>>checking for pj_transform in -lproj... yes
>>checking for pj_latlong_from_proj in -lproj... yes
>> using PROJ.4 from system libs.
>>checking whether we should include thread safe support...
>> thread safe support disabled.
>>checking whether we should include ESRI SDE support...
>> ESRI SDE support not requested.
>>checking whether we should compile in MPATROL support...
>> MPATROL support not requested.
>>checking whether we should include OGR support...
>>checking for gdal-config... (cached) /usr/local/bin/gdal-config
>>checking for OGRRegisterAll in -lgdal.1.1... (cached) yes
>> using OGR from system libs.
>>checking if GDAL support requested... yes
>>checking if PostGIS support requested... yes
>>checking for pg_config... (cached) /usr/local/pgsql/bin/pg_config
>>yes, user supplied pg_config
>>checking if OracleSpatial support requested... no
>>checking whether we should include WMS support...
>> OGC WMS compatibility enabled (-DUSE_WMS).
>>checking whether we should include WMS Client Connections support...
>>checking for libwww-config... (cached) /usr/local/bin/libwww-config
>> found libwww version 5.4.0
>> OGC WMS Client Connections enabled (-DUSE_WMS_LYR).
>>checking for potential conflict between system regex and rxposix...
>>checking for regexec in -lrx... (cached) no
>>Compiling with -DIGNORE_MISSING_DATA.
>>checking whether we should enable debug features...
>>checking for PHP/MapScript module options...
>> PHP/MapScript module not configured.
>>creating ./config.status
>>creating Makefile
>>but make ... resulsts as
>>gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>-DUSE_PROJ_API_H -DUSE_WMS -DUSE_WMS_LYR -DUSE_TIFF -DUSE_JPEG
>>-DUSE_GD_SWAP_XY -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS
>>-I/usr/include -I/usr/local/include -I/usr/local/include
>>-I/usr/local/pgsql/include -I/usr/local/include
>>-I/usr/local/include/w3c-libwww -DHAVE_CONFIG_H shp2img.o -L. -lmap
>>-L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz -ltiff -ljpeg -lfreetype
>>-lpng -lz -lproj -ljpeg -L/usr/local/lib -lgdal.1.1
>>-L/usr/local/pgsql/lib -lpq -L/usr/local/lib -lwwwxml -lxmltok
>>-lxmlparse -lwwwinit -lwwwapp -lwwwhtml -lwwwtelnet -lwwwnews -lwwwhttp
>>-lwwwmime -lwwwgopher -lwwwftp -lwwwfile -lwwwdir -lwwwcache -lwwwstream
>>-lwwwmux -lwwwtrans -lwwwcore -lwwwutils -lmd5 -ldl -lm -o shp2img
>>/usr/lib/libwwwapp.so: undefined reference to `HTZLib_inflate'
>>/usr/lib/libgd.so: undefined reference to `XpmReadFileToXpmImage'
>>collect2: ld returned 1 exit status
>>make: *** [shp2img] Error 1
>>HTZLib_inflate I can avoid,
>>but I really can't do anything with libgd.so ..
>>Any ideas?
>>TIA
>>Dragos Lipan
>>TI
>>Parcul National Piatra Craiului
>>2223 Zarnesti
>>Str. Raului. 27
>>Tel/fax (04)(068)223008
>>dlipan at pcrai.ro
Dragos Lipan
TI
2223 Zarnesti
Str. Raului. 27
dlipan at pcrai.ro
