[mapserver-users] Shapefile Modification
Keith Baker
krbaker at metacarta.com
Mon Nov 4 16:09:37 EST 2002
I was thinking about doing this with the perl shapelib bindings if I
couldn't find anyone with a tool. Its a pretty simple task which would
make a great utility.
Say I have shapefile with polygons (the us for example)
Then I have another shapefile which has a bunch of lines. (say from all
of north america)
I want to remove all lines within the polygons (US), (ideally) trim the
lines crossing the boundry, keep others...
Here is my issue... I have all of vmap0 in shapefile. I want to trim
out the US data that I have duplicated from tiger data. (roads, lakes,
etc)
What do you think?
On Mon, 2002-11-04 at 15:55, Frank Warmerdam wrote:
> Keith Baker wrote:
> > Humm... All suggestions turned out negitive.
> > ogr2ogr can remove things based on extent, but not based on another
> > shapefile. I may go hack away at it... not sure yet. Seems like
> > something someone must have done. I don't want to have to purchase
> > ArcView for this project if I can avoid it.
> Keith,
> I have been developing Python bindings for OGR. If you are willing to put
> up with some hassles, we could look at doing your filtering/changes as a
> python script using OGR. I have only been skimming this thread so you
> might need to repeat to me what you are wanting to do, but in general
> an aweful lot should be possible with OGR/Python.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021104/5c198da9/attachment.bin
