[mapserver-users] beginner getting started
Andrew Hallam
ahallam at digitalearth.com.au
Mon Nov 11 19:26:26 EST 2002
I run MapServer on Windows 2000 Server. In my opinion, there are two key
issues that you need to consider when planning to use MapServer on Windows:
1. Unless you have Visual C++ and know how to compile, you will be reliant
on downloading binary versions of MapServer. The binary versions may, or
may not, have all the features you require compiled into them. e.g. You may
be able to get binary versions that support FeatureX or FeatureY, but not
FeatureX and FeatureY. I suggest you check you requirements against the
available binaries.
2. If the web server will be on a network connected to the Internet you
have to let IIS respond to HTTP requests that contain "exe" files. i.e.
mapserv.exe. That means you cannot use URLScan to block all the automated
crack attempts that your server will receive from Code Red style worms and
malicious individuals. e.g. Request like "c/winnt/system32/cmd.exe",
"/MSADC/root.exe" and "/scripts/root.exe" will not get blocked so you have
to be extra careful with your security settings and patches.
When using Linux you obviously don't have to worry about Windows security
issues like Code Red et al attempting to get in via IIS, but you still have
to worry about security issues like the OpenSLL exploit.
My $0.02.
Regards
Andrew Hallam
Digital Earth Pty Ltd
http://www.digitalearth.com.au
