[mapserver-users] Couldn't run perl mapscript under Apache
Lowell Filak
lfilak at medinaco.org
Wed Nov 13 08:16:42 EST 2002
Next idea.
Please send your script.
Thanks.
Lowell F.
The following message was sent by "krung" <krung at cad.go.th> on Wed, 13 Nov 2002 12:48:01 +0700.
> Lowell and Puneet,
> I'd tried switch -w already, the same result. I suspect that my Apache has suexec enabled. It might cause the problem. I'll try to disable it but don't know how to now. I'll try with it.
> Thank you very much for your help and patience.
> Krung
> ---------- Original Message ----------------------------------
> From: "Lowell Filak"<lfilak at medinaco.org>
> Date: Tue, 12 Nov 2002 08:32:35 -0500
> >Okay.
> >First problem solved.
> >Now please try adding the -w switch to your script as Puneet has suggested and report what happens.
> >Lowell F.
> >The following message was sent by "krung" <krung at cad.go.th> on Tue, 12 Nov 2002 09:18:37 +0700.
> >> Lowell,
> >> If I ran at the command line "cat mapserver.log", it showed the error I tend to make in mapfile, e.g. I changed "UNITS KILOMETERS" to "UNITS KILO", it showed that it didn't know "KILO". If that mapfile worked without error, no new message's in that log file. And with this error-free script run on Apache, it stoped with "Internal Server Error" with no new message in mapserver.log and at the error_log of Apache, it showed only one line "Premature end of script header:/mapserver/testmap.pl". With this error_log file, I'm very sure it printed out only one line of error per access to this script.
> >> Thanks
> >> Krung
