[mapserver-users] Transparency problem
Daniel Morissette
morissette at dmsolutions.ca
Sat Nov 16 13:03:05 EST 2002
Alexander Pucher wrote:
> In the last line, I create an array containing the colors. I use this to
> draw a Legend with the GD functions offered by PHP.
> So atfer drawing the map with
> $image=$map->draw();
> $image_url=$image->saveWebImage(MS_PNG,1,1,0);
> I use a function that takes the recently drawn map as the basemap and
> renders the legend on it using the $colors array.
> How can changing the mapfile influence a PHP function, that has nothing
> to do with this mapfile?
The first thing I would check is make sure that your MapScript and your
PHP are built with exactly the same copy of the GD library.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
