[mapserver-users] list archive
Ranga Raju Vatsavai
vatsavai at cs.umn.edu
Fri Nov 22 19:31:13 EST 2002
Hello All,
As some of you must have noticed or faced this problem for last couple of
weekes. All our archivals (starting with fist message) are safe and available
for download. Only problem we are facing is with the web interface. We are
using 'Wilma' which is discontinued (no new release in last 3.5 years) long
back, but we sticked to it because it working fine till we upgraded the other
components recently. The interface is broken because Latest sendmail program
changed its header field slightly wich is not compatible with wilma/MHonArc
rules. We corrected the problem and you can find all mails through web interface.
Thanks for your patience. We are planning to migrate (at the end of this month)
from majordomo to mailman for mailing list management. May be at that time we can
also change web interface to some other reliable program. So any suggestions or
know-how of better software is welcome.
Thanks
Raju
> Raju, what has happened to the list archive? I see only a dump of the
> raw archive for October and November. The search engine seems to work,
> but it is very difficult to find back individual postings or threads.
> Jan Hartmann
