[mapserver-users] TIFFs no longer displaying
Ed McNierney
ed at topozone.com
Mon Nov 25 08:53:42 EST 2002
Dylan -
Your first step should be to install an error handler that tells you more about what's going on - the "Internal Server Error" can be translated into a more useful error message. Do you have a standard error handler you're using for IIS applications?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Sunday, November 24, 2002 10:40 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] TIFFs no longer displaying
I'm having a problem where TIFFs will no longer display in my
PHP-MapScript application. It's especially confusing because I can't
identify what changed on my system (nothing, as far as I can tell).
When I zoom in to the scale where DRGs are displayed, the app crashes
with a 500 Internal Server Error. This also happens if I put together a
simple mapfile to display a single DRG, along with a simple PHP
interface to just display the image. The error_log prints a standard
"Premature end of script headers" error.
However, shp2img *is* able to process these mapfiles (including the TIFF
images) and render the output. tiffinfo has no problem reading the
files, and permissions are not the problem. This makes me think the
problem is with PHP or something else at that level, but I've recompiled
and tested newer and older versions of PHP along with different versions
of MS, GDAL, and GD, and can't shake this problem. I've gone so far as
to completely install a separate MapServer environment (MS 3.7 cvs, GDAL
cvs, GD 2.0.7, PROJ 4.4.5, Apache 2.0.43, PHP 4.2.3, libwww 5.4.0) to a
different directory tree, to no avail. GDAL was compiled with internal
libtiff and libgeotiff support.
I'm hoping someone might have another idea of how to troubleshoot, given
that shp2img works. I've spent a couple days troubleshooting this and
can't seem to make a dent.
Thanks a lot,
Dylan
