[mapserver-users] Error Creating View...
Jan Hartmann
jhart at frw.uva.nl
Wed Nov 27 05:29:36 EST 2002
João,
This subject has been discussed several times on the PostGIS-users
list. A few days ago it has been added to the PostGIS documentation (
http://postgis.refractions.net/docs/x549.html#AEN607 ). The thing to
remember is that PostGIS uses items that are not available in views (or
subselects): a unique identifier field (called OID in regular tables)
and a projection number (SRID). Both are automatically available in
regular tables, but in a view or a subselect you have to add them
explicitly. You do this by adding "using UNIQUE=<unique variable> using
SRID=<srid>" to the MapServer DATA statement. Of course, The <unique
variable> should be included when creating the view.
Hope this helps,
Jan Hartmann
João Mário wrote:
> Hello to all
> I'm using PostGIS and Mapserver versions 0.7.3 and 3.6.3.
> I'm tried to create a view from the main table and call it in the
> mapfile, but it doesn't work....
> The code is this:
> LAYER
> CONNECTIONTYPE postgis
> NAME Roads
> CONNECTION "user=postgres dbname=dbase"
> DATA "geometry_field from table_view"
> FILTER "id_sec=1"
> STATUS ON
> TYPE LINE
> # LABELITEM "tile_name"
> CLASS
> NAME "Road 1"
> TEMPLATE "Road_1.html"
> EXPRESSION ([tipo_log]=2)
> COLOR 85 85 85
> SYMBOL 'line'
> SIZE 10
> MINSIZE 3
> MAXSIZE 15
> OVERLAYCOLOR 168 168 0
> OVERLAYSYMBOL 0
> OVERLAYSIZE 3
> OVERLAYMINSIZE 1
> OVERLAYMAXSIZE 2
> SIZE 15
> # LABEL
> # TYPE truetype
> # FONT arial-bold
> # SIZE 14
> # ANTIALIAS
> # COLOR 0 0 0
> # OUTLINECOLOR 255 255 255
> # PARTIALS OFF
> END
> CLASS
> NAME "Road"
> TEMPLATE "Road_2"
> EXPRESSION ([tipo_log]=1)
> COLOR 85 85 85
> SYMBOL 'line'
> SIZE 5
> MINSIZE 3
> MAXSIZE 15
> OVERLAYCOLOR 255 255 255
> OVERLAYSYMBOL 0
> OVERLAYSIZE 3
> OVERLAYMINSIZE 1
> OVERLAYMAXSIZE 2
> SIZE 15
> END
> END
> when i execute the following error apears:
> msPOSTGISLayerWhichShapes(): Query error. prep_DB:Error executing
> POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed too).
> DECLARE mycursor BINARY CURSOR FOR SELECT
> tipo_log::text,asbinary(force_collection(force_2d(geometry_field)),'NDR'),OID::text
> from table_view WHERE (id_sec=1) and (geometry_field && setSRID(
> 'BOX3D(1430.3002 760.3,1730.1002
> 1120.3)'::BOX3D,find_srid('','table_view','geometry_field') ))
> What could be wrong?
> Thanks
> João
Jan Hartmann
Departmen of Geography
University of Amsterdam
jhart at frw.uva.nl
