[mapserver-users] HTML Legend with Status Checking...
Martin, Daniel DMartin at erac.com
Tue Oct 1 12:18:30 EDT 2002
Perhaps I misunderstood.  By default (no opt_flag set) layers that are out
of scale and layers that have a STATUS off will not show in an HTML legend.
A legend exactly like this should do exactly what it sounds like you want:
[leg_class_html]
<TR>
  <TD>
   <img src="[leg_icon]" border=0>
  </TD>
  <TD>
    <font face="arial" size=2>[leg_class_name]</font>
  </TD>
</TR>
[/leg_class_html]
I'm not sure why you are having trouble getting the default action.  Perhaps
you could provide your current legend.
-Dan
-----Original Message-----
Sent: Tuesday, October 01, 2002 10:59 AM
To: Martin, Daniel
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] HTML Legend with Status Checking...
Thank you, but this didn't change a thing.  Actually, let me correct
that...it had a negative effect because now all my layers show up too,
even if they are not displayed in the map.  I want only active layers to
show in the legend and I want only IN-SCALE class symbols to show up in
the legend, I don't want 4 symbols to show up in the legend for every
layer that I have which has scale-specific classes...I just don't guess
I can do that without converting everything over to Mapscript.  X-(
Any other ideas?
Martin, Daniel wrote:
>You probably want a bit mask of 2 in your opt_flag.  Layers with STATUS off
>still show, but layers out of scale don't show.
>[leg_layer_html opt_flag=2]
>Per http://mapserver.gis.umn.edu/doc36/html-legend-howto.html :
>1: If set, show layer even if out of scale (default: hide layers out of
>scale).
>2: If set, show layer even if status is OFF (default: hide layers with
>STATUS OFF).
>4: If set, show layer even if type is QUERY (default: hide layers of TYPE
>QUERY)
>8: If set, show layer even if type is ANNOTATION (default: hide layers of
>TYPE ANNOTATION)
>In my experience, opt_flag=2 is the most intuitive.
>-Dan
>From: Mike Smith [mailto:nospam at cnrit.tamu.edu]
>Sent: Monday, September 30, 2002 5:06 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [mapserver-users] HTML Legend with Status Checking...
>Hello,
>    I've seen how you can make legends using PHP Mapscript that check to
>see whether a layer or class is in scale before displaying it in the
>legend, but no mention of how to do this if I'm not using Mapscript.  I
>have sub-classed many of my layers so that symbols show up in different
>sizes depending on how far zoomed in you are.  In other words, I'm using
>"MINSCALE" and "MAXSCALE" in my classes, but all of my classes show up
>in the legend and that's really annoying!  I want ONLY the in-scale
>symbol to show up in the legend as it does in the map...any tips on how
>to do this without Mapscript?  I see the "if" conditional statements in
>the HTML Legend How-to, but there's no status of "SCALE" to check with
>those statements... if I could put an if statement in my legend template
>that checked whether or not a class or layer was in scale, then I'd be
>in business...any way to do this?
>Thanks!
