[mapserver-users] HTML Legend with Status Checking...
Mike Smith
nospam at cnrit.tamu.edu
Tue Oct 1 12:56:02 EDT 2002
Same thing. Now I don't have group header bars seperating my layers,
but all the layers still show up and when I click on a layer that has
scale-specific classes, the symbols for all scales still show up. By
the way, I'm on Mapserver 3.6.1 and here's the page to go to if you want
to see what I'm talking about:
http://cnrit.tamu.edu/maps/map_init.html
Click on the very last button on that page (the one that says "FRAMES
VERSION" on it). When the map shows up, expand the "Regional" folder on
the left-hand side to display those layers. The one that I'm working on
right now is called "Parima Survey Households". Click on that layer to
load it into the map, then you'll see the various symbols I'm referring
to show up in the legend. I represent the Parima households with red
triangle symbols and I have different sized triangles depending on how
far zoomed in you are so that they are small at a high scale and larger
as you zoom in...but I don't want all versions of that symbol to show up
in my legend all the time...just the one that's in scale.
Thanks again!
Martin, Daniel wrote:
> Try this. Take out the leg_group_html section, and the leg_layer_html
> section, leaving only the leg_class_html section. Take them out
> entirely - don't leave an empty set of tags. Then, let me know what
> happens.
> -Dan
> -----Original Message-----
> From: Mike Smith [mailto:nospam at cnrit.tamu.edu]
> Sent: Tuesday, October 01, 2002 11:33 AM
> To: Martin, Daniel
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] HTML Legend with Status Checking...
> Gladly. Here is my legend code:
> [leg_group_html]
> <tr>
> <td colspan=3 bgcolor=#cccccc><b>[leg_group_name]</b></td>
> </tr>
> [/leg_group_html]
> [leg_layer_html]
> [/leg_layer_html]
> [leg_class_html]
> <tr>
> <td width=15> </td>
> <td>
> <img src="[leg_icon width=15 height=15]" width=15 height=15>
> </td>
> <td>
> [leg_class_name]
> </td>
> </tr>
> [/leg_class_html]
> However, it does not work as you say (and as the documentation on
> the web page says!). Layers that are "off" do not show up (that's
> as expected and what I want), that's fine, but layers that are out
> of SCALE DO show up, and that's not as expected and that's not as
> the documentation states and that's NOT what I want. For example,
> I have a layer called Ethiopia_Rivers...here's what it looks like:
> LAYER
> NAME "Ethiopia_Rivers"
> TYPE LINE
> STATUS off
> GROUP Ethiopia
> DATA "ethiopia_rivers"
> HEADER 'ethiopia_rivers.shp_header.html'
> CLASS
> MAXSCALE 8710165
> Name 'Ethiopia Rivers'
> COLOR 102 204 255
> TEMPLATE ethiopia_rivers.shp_query.html
> END # CLASS
> END # LAYER
> Now, when I'm viewing my map at full extent, my scale factor is 1:
> 20136789, therefore if I click on the Ethiopia_Rivers layer at
> that zoom level, nothing shows up in the map. This is the exact
> behavior that I would expect...I'm out of scale for that layer, so
> it doesn't show up in the map until I zoom in. The PROBLEM,
> however, is that the "Ethiopia Rivers" icon and label pop up in my
> legend...this is counter-intuitive, contrary to the documented
> behavior of Mapserver, and just flat-out frustrating! If the
> layer is not showing up in my map (because it's out of scale),
> then it should NOT be in my legend either. Grrrr!!! Pardon me
> for sounding bitter...I'm not lashing out at you, I'm very
> grateful for your help, I'm just frustrated at Mapserver.
> Thanks!
>>Perhaps I misunderstood. By default (no opt_flag set) layers that are out
>>of scale and layers that have a STATUS off will not show in an HTML legend.
>>A legend exactly like this should do exactly what it sounds like you want:
>>[leg_class_html]
>><TR>
>> <TD>
>> <img src="[leg_icon]" border=0>
>> </TD>
>> <TD>
>> <font face="arial" size=2>[leg_class_name]</font>
>> </TD>
>></TR>
>>[/leg_class_html]
>>I'm not sure why you are having trouble getting the default action. Perhaps
>>you could provide your current legend.
>>-Dan
>>Sent: Tuesday, October 01, 2002 10:59 AM
>>To: Martin, Daniel
>>Cc: mapserver-users at li!
>>sts.gis.u
>>mn.edu
>>Thank you, but this didn't change a thing. Actually, let me correct
>>that...it had a negative effect because now all my layers show up too,
>>even if they are not displayed in the map. I want only active layers to
>>show in the legend and I want only IN-SCALE class symbols to show up in
>>the legend, I don't want 4 symbols to show up in the legend for every
>>layer that I have which has scale-specific classes...I just don't guess
>>I can do that without converting everything over to Mapscript. X-(
>>Any other ideas?
>>>You probably want a bit mask of 2 in your opt_flag. Layers with STATUS off
>>>still show, but layers out of scale don't show.
>>>[leg_layer_html opt_flag=2]
>>>Per http://mapserver.gis.umn.edu/doc36/html-legend-howto.html :
>>>1: If set, show layer even if out of scale (default: hide layers out of
>>>scale).
>>>2: If set, show layer even if status is OFF (default: hide layers with
>>>STATUS OFF).
>>>4: If set, show layer even if type is QUERY (default: hide layers of TYPE
>>>QUERY)
>>>8: If set, show layer even if type is ANNOTATION (default: hide layers of
>>>TYPE ANNOTATION)
>>>In my experience, opt_flag=2 is the most intuitive.
>>>-Dan
>>>From: Mike Smith [mailto:nospam at cnrit.tamu!
>>>.edu]
>>>Sent: Mo
>>>nday, September 30, 2002 5:06 PM
>>>To: mapserver-users at lists.gis.umn.edu
>>>Subject: [mapserver-users] HTML Legend with Status Checking...
>>>Hello,
>>> I've seen how you can make legends using PHP Mapscript that check to
>>>see whether a layer or class is in scale before displaying it in the
>>>legend, but no mention of how to do this if I'm not using Mapscript. I
>>>have sub-classed many of my layers so that symbols show up in different
>>>sizes depending on how far zoomed in you are. In other words, I'm using
>>>"MINSCALE" and "MAXSCALE" in my classes, but all of my classes show up
>>>in the legend and that's really annoying! I want ONLY the in-scale
>>>symbol to show up in the legend as it does in the map...any tips on how
>>>to do this without Mapscript? I see the "if" conditional statements in
>>>the HTML Legend How-to, but there's no status of "SCALE" to
>>>check with
>>>those statements... if I could put an if statement in my legend template
>>>that checked whether or not a class or layer was in scale, then I'd be
>>>in business...any way to do this?
>>>Thanks!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021001/0be90efb/attachment.html
