[mapserver-users] Antialiased Lines in mapserver?
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 7 22:14:58 EDT 2002
woodbri at swoodbridge.com wrote:
> Which raises another question in my mind.
> Would it make sense to or is it planned that the output routines will
> be installable or selectable at runtime (maybe via the map file) so
> for applications that need the performance but can live with GD 1.x
> image quality can get it, while other apps can get the features they
> need?
Steve,
GD 1.x vs. GD 2.x cannot be selected at runtime as things are currently
setup because there is one "gd" interface with a few compile time
differences between 1.x and 2.x.
> Shouldn't it be possible to have output drivers for GD 1.x, GD 2.x,
> ImageMagick, Postscript, Flash, etc. Assuming that someone implements
> each of them.
It *is* possible to have GD, Flash, GDAL and potentially other output
mechanisms all compiled in and selected at runtime. The IMAGETYPE directive
directive selects which is used in a particular run.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
