[mapserver-users] 3.6.3 Compile problems/errors
Steven Bowden
steveb at bundaberg.qld.gov.au
Tue Oct 8 20:24:30 EDT 2002
Hi List,
I just tried to upgrade to 3.6.3 and received the following error when I
tried to access my application:
Warning: MapServer Error in msSaveImage(): (1034121816212081.png) in
/var/www/html/blis/blis.phpm on line 217
Fatal error: Failed writing image to 1034121816212081.png in
The relevant code from my php mapscript is
$image=$map->draw();
$image_url=$image->saveWebImage($config[image_type],1,1,$config[image_quality]);
The mapserver configuration options that I used to compile this version
were exactly the same as the ones that I used to compile 3.6.2 which
works without any problem. Here are the options that I used:
./configure --with-proj --with-wmsclient --with-libwww --with-gdal
--enable-runpath --with-php=../php-4.1.2 --without-tif --with-gd
--with-postgis --with-freetype=/usr/include --enable-force-freetype1
I am running mapserver on RedHat 7.3 and using php 4.1.2.
Anyone got any hints on what the problem could be?
I think it is something to do with the php_mapscript.so because I
reverted back to the php_mapscript.so compiled with 3.6.2 and the
mapserv 3.6.3 cgi and it doesn't produce the error.
Regards
Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021009/722cb5f3/attachment.html
