[mapserver-users] error building mapserver 3.6.3 on OS X 10.2
Zak James
zak-ms at aiya.dhs.org
Thu Oct 10 10:45:57 EDT 2002
With OS X 10.2, the default compiler is now gcc 3.1 which has some
trouble with mapserver. The easiest way to get around the problem is to
use the built in gcc_select script. As root, gcc_select 2 will switch
to the old compiler, which is still available. You can switch back by
issuing gcc_select 3.
zj
On Thursday, Oct 10, 2002, at 00:46 America/Montreal, Puneet Kishor
wrote:
> while make-ing, the program ends with the following --
> ranlib libmap.a
> ranlib: file: libmap.a(mapthread.o) has no symbols
> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> -DUSE_PROJ_API_H -DUSE_WMS -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG
> -DUSE_GD_WBMP -DUSE_GD_FT -I/usr/local/include
> shp2img.c -o shp2img.o
> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> shp2img.o -L. -lmap -lgd -L/usr/local/lib -lgd -ljpeg
> -L/usr/local/lib -lpng -lz -ljpeg -L/usr/local/lib -lpng -lz -lproj
> -ljpeg -lm -o shp2img
> ld: Undefined symbols:
> ___gxx_personality_v0
> make: *** [shp2img] Error 1
