[mapserver-users] error building mapserver 3.6.3 on OS X 10.2
    Puneet Kishor
    pkishor at GeoAnalytics.com
    Thu Oct 10 08:24:52 PDT 2002
On Thursday, October 10, 2002, at 09:47  AM, Daniel Morissette wrote:
> Puneet Kishor wrote:
>> by Sean Gillies...
>>> 2) The error
>>>    undefined reference to `__gxx_personality_v0'
>>>    tells you that you need to link shp2img using
>>>    g++ rather than gcc because one of your libraries
>>>    has C++ code.
>>> If you're not using gcc 3.x, please disregard my
>>> suggestions.
>> looking at my errors below, this seems to be a similar problem. I _am_
>> using gcc 3.1. I have no way of reverting back to an earlier gcc
>> version. Is this a known problem? Is there a workaround?
> Known problem?  Yes, you're not the first one to run into this.
> Workaround?  Unfortunately there is no fix for this yet in the
> mapserver
> distribution. Did you try Sean's suggestion?  It would involve editing
> the Makefile to use 'g++' instead of $(CC) as the name of the command
> to
> use for the mapserv: target.
ok, in the Makefile, around line 130, I made the following change
# Pick a compiler, etc. Flex and bison are only required if you need to
modify the mapserver lexer (maplexer.l) or expression parser
(mapparser.y).
CC=   g++
but that caused even more errors right at the begining. So, I tried the
following --
CXX= g++
CC= gcc
That fared a bit better in that it basically replicated what was
happening earlier. Error at shp2img. Is there someother place that I
had to change the Makefile?
Thanks.
More information about the MapServer-users
