[mapserver-users] Sudden failure to find libttf.so.4.0
gisweb at lmi.net
gisweb at lmi.net
Thu Oct 10 18:43:31 EDT 2002
Thanks, Daniel, this makes sense.
The confusing thing is, how did I make mapserv work initially? I've never had
root access to the system or the Apache httpd.conf (or any other conf) file. I
built the mapserv program referencing a mixture of already-installed
system-level libraries such as proj4 as well as locally built libraries such as
gd and libttf. None of these steps touched the httpd.conf file, so, why does
modifying it now fix the LD_LIBRARY_PATH problem?
(I've contacted the sys-admin people at the hosting service, so this question is
pure curiosity--please ignore if not interested in responding.)
Thanks again,
Jonathan W. Lowe
www.giswebsite.com
Quoting Daniel Morissette <morissette at dmsolutions.ca>:
> I can't explain why this happened (only your system admin could), but it
> is very likely that something changed on the server and
> /usr/home/gisweb/local/lib/ is no longer part of the runtime library
> path of the user running the web server.
> On Linux, you could edit /etc/ld.so.conf and add this path, and then run
> /sbin/ldconfig to rescan the library path.
> You could also use the following in your Apache httpd.conf:
> SetEnv LD_LIBRARY_PATH /usr/home/gisweb/local/lib
> PassEnv LD_LIBRARY_PATH
> (make sure you include any other required path in LD_LIBRARY_PATH as
> well)
> Daniel
> gisweb at lmi.net wrote:
> > Mighty List:
> > Successful install of mapserver version 3.6.1 on our FreeBSD platform put
> smiles
> > on all faces. Performance and cartographic quality were magnificent. The
> build
> > consisted of the following options:
> > > /usr/home/gisweb/www/cgi-bin/mapserv -v
> > MapServer version 3.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORT
> > S=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=SHAPEFILE
> > Smiles vanished, however, when mapserver suddenly ceased working yesterday.
> The
> > apache error_log reports the following:
> > > tail -3 /usr/home/gisweb/www/logs/error_log
> > ld.so failed: Can't find shared library "libttf.so.4.0"
> > [Wed Oct 9 18:53:58 2002] [error] [client 32.102.91.129] Premature end of
> scrip
> > t headers: /usr/home/gisweb/www/cgi-bin/mapserv
> > And yet, gentle reader, the supposedly missing libttf.so.4.0 library
> remains
> > where it has always been, exactly where mapserv expects to find it (as
> > illustrated by the output of ldd and confirmed by the output of ls -l).
> > > ldd /usr/home/gisweb/www/cgi-bin/mapserv
> > /usr/home/gisweb/www/cgi-bin/mapserv:
> > -lm.2 => /usr/lib/libm.so.2.0 (0x2007a000)
> > -lpng.3 => /usr/local/lib/libpng.so.3.0 (0x20094000)
> > -lz.2 => /usr/lib/libz.so.2.0 (0x200ad000)
> > -ljpeg.9 => /usr/local/lib/libjpeg.so.9.0 (0x200b9000)
> > -lttf.4 => /usr/home/gisweb/local/lib/libttf.so.4.0 (0x200d5000)
> > -lpdf.1 => /usr/local/lib/libpdf.so.1.1 (0x200fa000)
> > -ltiff.3 => /usr/local/lib/libtiff.so.3.0 (0x20121000)
> > -lproj.3 => /usr/local/lib/libproj.so.3.1 (0x2015e000)
> > -lc.3 => /usr/lib/libc.so.3.1 (0x2018c000)
> > > ls -l /usr/home/gisweb/local/lib
> > total 1396
> > -rw-r--r-- 2 gisweb wheel 10194 Sep 20 09:04 gd.h
> > -rw-r--r-- 2 gisweb wheel 917 Sep 20 09:04 gd_io.h
> > -rw-r--r-- 1 gisweb wheel 185736 Sep 20 09:04 libgd.a
> > -rw-r--r-- 1 gisweb wheel 436250 Sep 24 13:54 libmap.a
> > -rwxr-xr-x 1 gisweb wheel 641 Sep 20 08:33 libttf.la
> > -rwxr-xr-x 1 gisweb wheel 757868 Sep 20 08:33 libttf.so.4.0
> > Who can explain this unusual twist of fate and restore mapserv to its
> original
> > triumphant glory?
> > Don't hesitate, gentle reader; speak up! Let the bells of freedom ring!
> > Ever hopefull,
> > Jonathan W. Lowe
> > www.giswebsite.com
