[mapserver-users] PythonMapscript Installation under Windows
Schuster
Grit.Schuster at uni-vechta.de
Fri Oct 11 07:36:16 EDT 2002
Hi everybody,
I tried to compile pythonMapscript (MS 3.6.2) under Windows 2000 with Python
2.1.3, SWIG 1.3.15 and MSVC7 compiler, using Norman Vine's setup.py script.
I tried to modified it to reflect windows requirements concerning directories
and
libraries.
When I run the setup, there is a problem when building the MapScriptc
extension.
I get the following error (translated from german):
mapscript_wrap.obj: error LNK2001: unresolved external Symbol initMapscriptc
build\temp.win32-2.1\Release\MapScriptc.lib: fatal error LNK 1120: 1 unresolved
external references
LINK : fatal error LNK1141: build export file error
error: command 'link.exe failed with exit status 1141
Has anybody had simliar problems or gathered experience building the mapscript
extension for python under windows? I attach below the modified setup script in
case someone wants to take a look at it.
TIA, Grit
setup.py:
#! /usr/bin/env python
# Distutils setup for UMN Mapserver mapscript v.3.5
# Norman Vine 11/10/2001
# On cygwin this will require my Distutils mods available @
# http://www.vso.cape.com/~nhv/files/python/mydistutils.txt
# Should work as is on 'Unix' like systems
# needs testing on Windows compilers other then Cygwin
# To Install
# build mapserver
# Copy this file to $MAPSERVER_SRC / mapscript / python
# invoke as ./setup.py install
# should work on any python version with Distutils
__revision__ = "$Id: mapscript_setup.py,v 1.5 2001/11/10 15:22:02 nhv Exp $"
from distutils.core import setup, Extension
from distutils.spawn import spawn
from distutils.dir_util import mkpath
from distutils.file_util import copy_file
from distutils.sysconfig import parse_makefile
import os,sys
from os import path
noisy=1
swig_cmd = ["d:\ms\swig-1.3.15\swig",
"-python",
"-shadow",
"-module",
"MapScript",
"-o",
"./mapscript_wrap.c",
"../mapscript.i" ]
try:
spawn(swig_cmd, verbose=noisy)
except:
print "\nSwig Error"
raise sys.exit()
# make package directory and package __init__ script
mkpath("mapscript")
init_file=open(path.join("mapscript","__init__.py"),"w")
init_file.write("from MapScript import *\n")
init_file.close()
copy_file("MapScript.py", path.join("mapscript","MapScript.py"), verbose=noisy)
# change to reflect the gd version you are using
gd_dir="gd-1.8.4"
ms_dir=path.join("D:\ms\mapserver-3.6.2")
local_dir="D:\ms"
freetype="freetype\lib"
png_dir="lpng124"
proj="proj\src"
tiff="tiff-v3.5.7\libtiff"
oracle_inc="d:\oracle\ora81\oci\include"
oracle_lib="d:\oracle\ora81\oci\lib\msvc"
regex_dir="regex-0.12"
setup (# Distribution meta-data
name = "pyMapScript",
version = "3.6",
description = "pre release",
author = "Steve Lime",
author_email = "steve.lime at dnr.state.mn.us",
url = "http://mapserver.gis.umn.edu/",
# Description of the modules and packages in the distribution
packages = ['mapscript'],
ext_modules =
[Extension('MapScriptc', ['mapscript_wrap.c'],
define_macros=[('TIFF_STATIC',),('JPEG_STATIC',),('ZLIB_STATIC',),
('IGNORE_MISSING_DATA',),('USE_EPPL',),('USE_PROJ',),('USE_PROJ_API_H',),
('USE_WMS',),('USE_WMS_LYR',),('USE_TIFF',),('USE_JPEG',),('USE_GD_PNG',),('USE_
G
D_GIF',),('USE_GD_JPEG',),
('USE_GD_WBMP',),('USE_GDAL',),('USE_ORACLESPATIAL',)],
include_dirs=[ms_dir,
path.join(local_dir,gd_dir),
path.join(local_dir,freetype),
path.join(local_dir,tiff),
path.join(local_dir,oracle_inc),
path.join(local_dir,proj),
path.join(local_dir,regex_dir)],
library_dirs=[ms_dir,
path.join(local_dir,oracle_lib),
path.join(local_dir,png_dir)],
extra_objects=[path.join(ms_dir,'mapserver.lib'),
path.join(local_dir,'gdal\ogr\ogrsf_frmts\ogrsf_frmts.lib'),
path.join(local_dir,'gdal\gdal.lib'),
path.join(local_dir,'gdal\ogr\ogr.lib'),
path.join(local_dir,'gdal\port\cpl.lib')],
libraries=['gd','gdft','freetype','ttf','proj','pq','png','z'],),
libraries=['gd','freetype','libpng','proj','zlib','oci'],),
